Question about Apple Cinema Display 23" HD Monitor
Apple 23" cinema display
My 23" Apple cinema display as gone dead and all I get is two (2) short and one long power light flashes.
  • 3 more comments
  • camron Malherbe Nov 24, 2008
    Exactly the same problem.  what is a faulty power brick?
  • CieloYLluvia Nov 25, 2008
    Same problem. My CD is connected to a G5, both purchased in 2005. When it was under Apple Care, they replaced the power brick (90w). This time, I purchased a new 150 W power brick on my own dime, and it still is dead. Sometimes it comes up, but with no rhyme or reason. I've tried all kinds of cable connect variations and zapped my prams. Still not working. :(
  • jotzet Dec 07, 2008
    it's quite strange that so many people have the same problem, since end of september... could this be related to mac os x 10.5.5? could this be related to a new product named Apple LED Cinema Display? i have a strong supsicion, that apple wants me to switch to a new display...
  • ATOMICBOY Dec 28, 2008
    I've got the same problem, as of today. It is the second monitor connected to my system. Switched the monitors to the other ports and it's definitely the monitor, not the card.
     It started out intermittently the other day. Wouldn't wake from sleep. Would have to restart. Then restart wouldn't work. Had to power all the way down and start it up again. Now nothing works. Disconnect it. Unplug it. Nothing.
  • Anonymous May 04, 2009
    Same problem. Replaced power brick. No fix.
Thats supposed to mean theres a faulty powerbrick, however i have the same problem on mine and replacing that didn't solve it
Posted on Oct 31, 2008
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
Apple cinema display 23"
Hello!
Please do and verify any fuse blownout in the inlet of the power from the wall, if it is not visible then maybe you open the the back cover and try to see any parts that has error or blown. you should replace it with genuine replacement parts. however it hard to do this by a novice tech, My suggestion is to bring the unit to the nearest service center maybe the unit got warranty service or else maybe its a cheap or resonable cost.
may this help!
best regards, melnavz
Mar 03, 2008 | Apple Cinema Display 23" HD Monitor
Aple HD Cinema Display 23" is dead, no front LED light or back display light
Contact Apple support by phone 1 (800) 204-4427 US toll-free or chat, set up a repair, or make a Genius Bar appointment for iPhone, iPad Apple Mac Technical Support Phone Number 1 800 204 4427
Jun 14, 2017 | Apple Cinema Display 23" HD Monitor
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
Power connector on cinema display is damaged. Can it be replaced?
Hello, GREAT NEWS!!! Yes you can replace it. Try going onto Ebay and punch in: A1097 Apple cinema display power ac adapter 90W 23" LCD.
May 05, 2010 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Jul 19, 2009 | Apple Cinema Display 23" HD Monitor
Apple 23" Cinema HD Display went off
Hey - I just got done with 30 minutes of trying my cinema HD on my macbook pro and plugging and unplugging. When I plugged it into an extension cord in another socket the monitor started right up. I've had this configuration in my office for years with no problem...until today. Did mac send us a system upgrade that caused a problem with the monitor's power source???? Good luck!!!!
Jul 28, 2008 | Apple Cinema Display 23" HD Monitor
Apple Cinema Display 23" HD Monitor Logo
1,902 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
