Question about Mitsubishi WT-46809 46" Rear Projection Television
Cleaning How do I get to the screen behind the diamon shield for cleaning?
    President:
  • 3,130 Answers
Every manufacturer has a differant procedture to disassemble the screen assembly. If you got the service manual from http://www.servicemanuals.net you would be able to take the set apart without damaging anything.
Posted on Sep 02, 2006
How can i clean the screen
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user\'s manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV\'s can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can\'t tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it\'s extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions. GA_googleCreateDomIframe(\'google_ads_div_TL-IMU-Article\' ,\'TL-IMU-Article\');
Jun 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
Tip
How to clean your dlp tv screen?
1.Check your TV to see if it has a screen shield. TVs with a screen shield are covered in protective plastic and are much easier to clean than those without them. Look at your screen and see if it appears to be smooth or bumpy. If you still can't tell, touch the screen lightly with the tip of one finger. If it has a shield, it will be hard and rigid; if not, it will be soft.
2.Clean a DLP TV screen that has a screen shield by wiping it with a dry microfiber cloth. Start at the top left and move side to side until you've covered the whole screen. Use gentle pressure and touch the screen only with the cloth, never with your hands. If just using the cloth doesn't get out a stubborn soil spot, dip the cloth in a bowl of distilled water that is at room temperature. Wring out the cloth and try wiping again.
3.Clean a DLP TV screen without a screen shield only with an approved screen cleaning kit. Your best bet is to purchase one directly from your TV's manufacturer. However, you can also find generic kits at most electronics stores. Each kit comes with a cloth and cleaner that will not damage the delicate screen. Follow the same side to side method to wipe the screen as outlined in step two. Again, avoid touching the screen with your hands.
4.Avoid letting liquid sit on the screen. Since you shouldn't use much, it should dry quickly. If it's still wet after two minutes, use a second microfiber cloth to dry.
on Mar 25, 2010 | Televison & Video
Intermediate Transfer Belt on a Canon IRC3100
Your going to have to pull off the waste toner bottle, delivery cover (buffer or internal finisher), the right swinging door, fixing unit, cleaning blade, heat shield, move the fuser drive gears. Then you have one screw on the transfer belt assy that sit behind the cleaning blade and one on the front next to the screw that hold the cleaning assy on. Then 4 screws on the side by the fuser. One connector and the whole thing should come out
Mar 10, 2009 | Canon iRC3100 Printer
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Cleaning behind front screen.
Sorry my friend. You and I both know the answer to this. A complete disassembly and cleaning is needed. A fire hazard is a very serious event waiting to happen. Take care of this ASAP!
Ray
Nov 06, 2008 | Holmes Products HQH307 Compact Heater
To clean the screen?
is it the shield or the screen itself ?
Oct 18, 2008 | Toshiba TZ50V51 50" Rear Projection...
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
How do i clean my screen
Oct 29, 2007 | RCA P52926 52" Rear Projection Television
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
