Question about Frigidaire Refrigerators
The water dispenser no longer dispenses any water on my Frigidaire FLSC238DSN refer. . The light comes on and there is a hum but no H2O. Checked line for kinks, etc. It was working fine and then qu
We recently replaced the plastic water actuator lever after the kids broke it off. Hooked everything back up and it was fine for several days and then just stopped dispensing water.
4 Suggested Answers
  • 1314 Answers
SOURCE: water dispenser lever
any appliace part store can just have right model off serial#plate in top of frigde compartment
Posted on Dec 31, 2007
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
  • 82 Answers
SOURCE: Replaced water actuator on frig and now it doesn't dispense water
pull it back open and double check you're wire connections
Posted on Jun 19, 2009
Water stopped coming out of the dispenser and it no longer makes ice. I checked water supply to the unit and everything was good. I have replaced the water filter.
Hello friend, thank you for your post!
From the information you have provided there is no water coming out of the dispenser or ice of your Frigidaire refrigerator. I see you have changed the water filter and still have no water flow. This could mean there is a clog within your water line or your water valve may not be pushing water into your refrigerator. You may need to seek assistance from a technician. They would have the appropriate tools needed for proper testing and disassembly of your refrigerator. This will help prevent any personal injuries or improper part replacement on your refrigerator. -Matt
Jan 04, 2016 | Frigidaire Refrigerators
Hello, I have a frigidaire side by side fridge and freezer ( LGUS2642LF2). Water stopped coming out of the dispenser and the ice cubes are coming out but is taking a very long time. I first replaced the...
Good Morning Friend,
I understand that you are having trouble with receiving water out of the dispenser area of your Frigidaire refrigerator, model# LGUS2642LF2.I also see that you have changed the water filter as well as checked and replaced the inlet valve with no positive results, other than it sounds like it wants to dispense water and makes a humming sound. I suggest resetting your refrigerator, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power has been restored, try getting water out of the dispenser. If you are still having trouble, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what the cause of your refrigerator not dispensing water. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Frigidaire Refrigerators
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Fabric softener dispensor does not empty
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softener dispenser water valve. Did you hear the solenoid hum? If so we will now need to turn on the Cold Water Inlet Valve and see if water flows to the dispenser.
Now press the Spin Only key this will turn on the Cold Water inlet valve after 5 seconds press the Off key. The washer will unlock. Check to see if water did flow to the fabric dispenser reservoir. If you heard the Fabric dispenser valve hum then most likely 120VAC was applied to the solenoid. If water did not flow then the Fabric dispenser valve is stuck closed if you heard it hum.
The Bleach/Fabric dispenser water valve is an assembly and is not repairable you have to replace.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Fabric dispenser solenoid.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price try appliancezone.com…
You can remove the Fabric Softner to clean see page 33 of the Service Manual…Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Filtered water quit working on my Frididaire side by side
although you had waterto the bottom of door when disconnected, did you try to dispense water while unhooked andsee it flow??? because just unhooking it will allow the resivoir of stord water to flow out by gravity, giving false sense of water working., if indeed it did work the you have a frozen water lin within the freezer door itself, ait tricky to defrost. aside form unplugging unit and allow to thaw out, or pulling line form liner not going to be easy to thaw the line. if you indded still hear the "hum" after disconnectng water under door, then it soundsas if you have a bad water inlet valve located behind refrig where the water atteachges to the refric, no repairingthe valve it needs replacing
Nov 20, 2008 | Frigidaire FRS26R4A Side by Side...
Water to the Ice maker and water dispenser has stopped
check to make sure the valve is not froze if so water cant come thru
Nov 11, 2008 | Frigidaire FRS26R4A Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser problem
You have some wires crossed on your water valve.   Check the connections on your valve.
If you need more help, go here and chat with me one on one about this
Thanks, Bill
Sep 07, 2008 | Frigidaire FRS26H5AS Side by Side...
Water Dispenser
GodofHops: The motor that you hear on the refrigerator is the water pump that carries the water to your dispenser. If no water is coming from the dispenser. You have to check 3 things: 1. If there's any water. 2. Water filter clogged. 3. Water line for dispenser clogged with minerales carried on water flow. SithPitt
Jul 04, 2007 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
