Question about RCA Televison & Video
Cannot find the option to scan channels for antennae
  • RCA Master
  • 1,214 Answers
Hi is the antenna option not on the remote control?
Posted on Feb 25, 2012
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
Nov 03, 2017 | Televison & Video
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
How do I run a channel auto scan?
There are many different ways, because each TV manufacturer calls each menu option something different. In your TV menu there should be an option that says Set Up, or Channels, or something similar. Your TV should be, Menu, pan right to Channel, select whether you are using Air (air meaning antenna, picking up channels that are broadcast free over the air) or Cable (only if you use cable with no box). Then the option below should be auto scan. Allow to run completely. Sanyo DP42D24 User Manual Channel
Apr 06, 2015 | Sanyo DP55D44 55" 1080p 60Hz LED HDTV
Just bought a !9" digital flat screen Apex. Hooked it to an indoor HDTV antenna. All I can get is "NO SIGNAL". What do I try next?? Bob E, Technical Dunce over 80.
Bob, If you have an hd ready tv, and hooked up the Ant. then the next thing you should do is go to your menu and select the tv feature and then scan for channels. This should program the channels for you. Most TV setups are like this. You should have a option for cable or antenna/tv input. select Antenna. You r should be good to go once the channel scan is done.
Hope that helps
Dan
Feb 26, 2015 | Televison & Video
How do i select the channel menu
Many times the re-scan tune option goes away if you've selected an input on the TV other than the "tuner", "Antenna" or similar (ie: AV1, HDMI1, Sat, Cable, etc.do not make use of your TV's internal tuner).
Make sure you select an input on your TV, ( tuner, etc.) that will use the tuner and have an antenna or non-digital Cable TV coaxial cable connected. Then attempt to scan again.
Dec 15, 2014 | Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Dec 06, 2010 | Televison & Video
Screen shows no signal
HDTV sets are different from the old analog sets.
If your set is showing No Signal or Weak Signal you will have to do the following.
1) Connect an Antenna or Cable to the input on the back.
2) Go into the Channel signal source menu and select either the Air/Antenna or Cable option.
3) Go into the Auto Program Scan menu and SCAN in the channels.
Now you can watch available channels.
Dec 29, 2008 | Polaroid FLM-3732 Television
Televison & Video Logo
23 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
