Question about Onkyo TX-DS656 Receiver
I can't find the speaker balance controls on my onkyo receiver tx sd 656.
SOURCE: Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Posted on Jun 11, 2008
SOURCE: Onkyo receiver audio problem
I have Found two problem which cause NO AUDIO 27-07-08
jaiki39@yahoo.com
  1. 1.Failed connection between top &bottom of circuit board NCDG-6575 (Dolby --DTS) processing board.
Near & under IC Q710
2.Failed componet IC Q710 part # LC372100PT
IF you disconnet CKT board NCDG-6575
you will get audio on speaker B left & right CH only
SOLUTION have CKT board NCDG-6575 Repaired or REPLACED
Posted on Jul 28, 2008
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
Gurudristi
  • 98 Answers
SOURCE: Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Posted on Mar 08, 2009
ONKYO TX-DS484: \r\nI am not getting any sound out of my left speaker on stereo. I cannot find a balance adjustment. I do not have the remote control. Thanks
It sounds like you also need the manual.
http://www.retrevo.com/support/Onkyo-TX-DS484-Receivers-manual/id/365dj182/t/2/
The remote is an RC-4278. You WILL need it.
$25.10 on eBay expiring tonight so jump on it. 3h 35m 40s (Sep 06, 201120:16:46 PDT)
http://www.ebay.com/itm/ONKYO-RECEIVER-REMOTE-CONTROL-RC-385S-RC-373M-RC-371M-/290597112430?pt=LH_DefaultDomain_0&hash=item43a8f00a6e
As far as the left speaker goes, swap it to decide if it's the speaker, wire or the amp channel. There are no control settings that would make one of the front pair go silent.
Sep 06, 2011 | Onkyo TX-DS484 Receiver
I have an onkyo tx-sr308 and I am receiving only static or very low music on my right speaker channel. Please help
Switch to the other set of speaker outputs (move from A to B). If it continues, you have a repair issue...assuming it happens with all inputs. If it only happens with DVD, or CD, or Tuner, or whatever, but works fine with other components, it's a connection issue - unplugging and replugging, or replacing cables may correct.
If I recall correctly, that unit doesn't have a standard twist knob style balance control. If it does, turn the unit off and rotate it through it's full range several times, then recenter it and try listening to it again.
Jun 25, 2011 | Onkyo TX-SV444 Receiver
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
Onkyo TX-8410, speaker selector B not operating. When I have the speaker selector on A&B or just B, the B speakers do not operate. If I switch the wires from the same speakers to the A channel, the...
http://www.retrevo.com/support/Onkyo-TX-8410-Receivers-manual/id/365ci162/t/2/
Individual speaker leads are not fused. It's possible the switch is defective. Does it light the speaker B indicator? If not, I'd suspect the switch.
If it DOES light the Speaker B indicator maybe there's an open circuit going to the Speaker B terminals. Or its common ground for that speaker pair alone is open.
May 17, 2011 | Onkyo TX-8410 Receiver
How to set-up the audio. I have 5 speakers and 1 subwoofer
It's all explained in the manual.
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
Your subwoofer needs it's own audio power (amp). I'm pretty sure the manuals for the speakers cover their requirements and set-up.
Apr 30, 2011 | Onkyo TX-SR608 Receiver
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Apr 09, 2011 | Onkyo TX-910 Receiver
How do I adjust the balance of the speakers? One
press setup on front. press speaker level control. use left and rt up and down buttons to select speaker and set levels. hit return to go back of setup to get out.
Mar 17, 2010 | Onkyo TX-SR504 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-DS656 Receiver Logo
98 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
