Question about HP DesignJet 1055CM Plus InkJet Plotter Printer
Want a wireless adapter for hp designjet 1055cm printer
I require to connect the printer with a wireless adapter, what is the best
PABLOCSA
  • 1124 Answers
SOURCE: connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Posted on Oct 03, 2008
713printech
  • 32 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Posted on Nov 19, 2008
  • 8 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
  • 24 Answers
SOURCE: HP DesignJet 450c printer issues.
Kavalbe,
You can find drivers for your DesighJet printer here:
Then, a JetDirect 170X or 300X will fit the bill for connecting the printer to the network.
Also, you preferably should use an HP Standard TCP/IP port for connecting the driver to the network, since the MS version in some cass have issues (prints can be reprinted when crossing over to a new date, prints can disappear...)
A stable version of HP's Standard Port Monitor can be found here: (Note, this is a direct ftp link to HP's ftp server, so you should get a file for downloading when you click the link.)
Else, you can use either the software that comes with the JetDirect box or download its software from hp.com. But the HP Standard Port Monitor software is easier to use if you already have the printer driver.
//Al
Posted on Mar 08, 2009
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
I just purchased a new computer that has windows 7 and 64 bit and my hp designjet 1055cm plus inkjet printer driver is no longer compatible, Do you know of a driver that will work?
It appears that HP has linked the wrong file to the driver download on the website. I would contact HP and get the correct link so that you can download the driver.
Jul 11, 2011 | HP DesignJet 1055cm plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
Ink tube leaking in HP designjet 1055cm
No repair parts available except for complete ink tube replacement. Part #C6072-60145. Depending how you get it, $250 to $600 with added labor if you can't do it yourself. Directions included in box.
Nov 30, 2010 | HP DesignJet 1055cm InkJet Printer
HP DesignJet 1055cm Plus system error: 04C300 001F0000.
Its either the EIO card, make sure its seated properly, or the hard disk drive has failed in your plotter. Try running the plotter with out the hard disk drive, it is static sensitive, so make sure your grounded before removing it.
Mar 19, 2010 | HP DesignJet 1050c plus InkJet Printer
Dead hard drive in 1055CM DesignJet Plotter to replace
you can run this printer without an hdd. disconnect the power from the hdd.you may have to disconnect the IDE controller (the small board that connects to the main pca) and disconnect the flat grey cable. this makes your DJ1055CM a DJ1050C it should print okay. you cannot format any hdd to work. you must buy the hdd from HP. if you can find one. good luck and i hope this helped.
May 28, 2009 | HP DesignJet 1055cm InkJet Printer
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead...
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Dec 10, 2008 | HP DesignJet 1055cm InkJet Printer
HP 1055cm printer drivers do not show up on MAC OS9.1 'chooser'
uninstall the Hp printer driver and software.
install the printer software from the CD. download the driver from HP (driver only).
Nov 13, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1055CM Plus InkJet Plotter Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
