Question about Jwin iLuv i322 Widescreeen Hands- Bluetooth Car Kit with Caller ID LCD Screen
Default pairing code for iluv i322
Chnged my iphone 4 to iphone 4s and I cannot remember the default pairing code
Pairing to i Phone
Reboot iPhone. Go to Settings, Bluetooth, switch off and then back on. Power up headphones. Press the button on the headphones that you need to press to send the signal to the iPhone (this is the part that most people don't get). When found, click Pair on the iPhone. If it asks for a code the default is 4 zeros '0000'.
for instructions Google
make model manual
or
make model instructions
Jul 25, 2016 | Radio Communications
Why my nabi2 pear with my iluv speaker but can't hear it ?
Pairing and connecting are different steps in the process of connecting two Bluetooth devices. As long as your headphones are not CONNECTED (not just PAIRED) with your tablet, you are not going to hear anything that you play on the tablet (music, video, etc.).
Jan 22, 2015 | ILuv Audio Players & Recorders
Why my nabi2 is pear with my iluv speaker but can't hear it ?
Probably because they are PAIRED, but not CONNECTED. Pairing and connecting are two different steps in the process of making two Bluetooth devices to communicate with each other. Read the manual on how to connect the two.
My Iluv Alarm with shaker for Iphones won't play any music when I try to connect it
do you have it set to the correct input?is the volume up on the phone and iluv?is the iluv device powered.is the iluv device turned on?is the iluv device compatible with you iOS device?Return the iluv device if all else fails it should work, also try using the aux port, many ios devices in fact will charge with other devices however not all iOS devices will interact with other devices, have more questions? just ask
Mar 29, 2013 | Audio Players & Recorders
I have had this bluetooth for a while but never used it. Trying to pair it With my new iPhone and dont remember having a PIN #. what do I do now? Or can I use it?
The default pass code is "0000."
Here's how to pair it with the default pass code:
  1. Turn the Bluetooth on and hold down the button until the light turns solid.
  2. Put the phone in discovery mode or search for a Bluetooth device.
  3. Pair the Bluetooth to the phone and enter the pass code "0000"
May 29, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have forgotten the pairing code for my samsung nc10, I've tried 0000 and 1234 also abcd. What would the default code be.
Usually default pairing code is 0000 but most times the code is whatever you set it up as. if you cant remember the code and the unit are requesting for a code simply delete the previous pairing and do a new pairing this should solve the problem instead of trying to remember a code which could be any 4 digits in the world.
Hope this solution has been helpful?
Apr 13, 2011 | Samsung NC10-14GW Notebook
Trying to pair my iphone via bluetooth with my hp laptop but I don't have the manual to enter any pin. Is there a generic pin like ''admin'' for wireless routers or am I screwed?
I think it might be 1234 0000 1111 or a default pair code, however, try other codes like a device lock code if applicable.
Jul 15, 2009 | Apple iPhone 3G
Not paired, Motorola Blue tooth H300 to iPhone 3G S
hi
when the bluetooth id discovered it has to be registered with the default code of 0000 over the handset to be paired
hope this helped
cheers
Jul 07, 2009 | Dual Electronics CECT P168 Cellular Phone
Jwin iLuv i322 Widescreeen Hands- Bluetooth Car Kit with Caller ID LCD Screen Logo
Top Jwin Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Jwin Cell Phone Expert? Answer questions, earn points and help others
