Question about Bernina 1008
Zigzag knob slips - Bernina 1008
  • Bernina Master
  • 7,365 Answers
It may have come loose in side & needs to be serviced
Posted on Feb 25, 2012
The zigzag stitch will adjust width but not length
If it's a mechanical Bernina, it could be some of the lever mechanics have seized from old, dry oil. You can try liquid Tri-Flow Synthetic Oil--a couple drops where metal rubs on metal to see if it loosens things up. Applying hot air from a handheld hairdryer will help speed it up. The other possible alternative is that something is no longer attached to the knob/lever.
If it is a computerized Bernina, you should probably take it for service.
Aug 04, 2016 | Bernina Sewing Machines
My dressmaker 7000 won't Change from straight stitch to zigzag the knob keeps going back to zero
sound like the machine may need to be serviced, to find out if there is a problem with the knob, see if there is a loose connection
Mar 22, 2016 | Sewing Machines
How to fix tight stitch adjustment knob
If your machine is mechanical (not computerized), it most likely needs a good cleaning and oiling. Here's a link that may be helpful. Of course, you will probably need to focus on the particular knob causing a problem, but the rest of the machine most likely would benefit from some attention.
Will not zigzag or decorative stitches New to these newer plastic style...
Jan 24, 2016 | Sewing Machines
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Straight stitch
Tension knob on any machine will be in the thread path and usually above the needle somewhere, while the stitch width and length knobs are usually on the right side of the machine. I cant identify your model but on any machine straight stitch is usually a length of 2.5 and width of 0, while a zigzag the width will be set somewhere between 2-4 depending on how wide you need it to be. There is usually a stitch selector of some sort too but many machines, providing the width is set to 0, you will get a straight stitch.
May 29, 2013 | Husqvarna Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
I have a globe 877 sewing machine but no manual and i can't figure out how to stop it zigzagging
The knob with dot and F & R should be set to the dot.
Thw slider should be at the white dot not the red dot. Red dot does forward only.
The rotary knob with WWW O === is the stitch selector.
This is the setting for straight and zigzag stitching
Stitch length control any number from 0.5 to 4
Stitch width control any number from 0 to 4
Special stitch modifier; Red dot
Buttonhole control; RED dot
Dec 10, 2010 | Sewing Machines
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
