I added a cheat code and my action replay dsi froze so i HAD to turn it OFF and now its coruppted
Uninstall your current Code Manager software, then download and install this: http://us.codejunkies.com/nds_actionreplay/SetupUS1_05.exe. It worked for me...finally have all the options, to add new game, new cheat...etc...
SOURCE: my action replay ds has corrupted files:need to un corrupt
All you have to reset it. To do that, turn off the DS, then hold down A+B. Keep holding them down while you turn on the DS. Just before the message that this product is not endorsed by Nintendo, and while still holding down A+B, hold down Start+Select. Keep holding all these down until the Enter Game Card screen comes up. It's tricky to keep all the buttons held down, so you might have to try it a few times before it's really reset. You'll know if it's reset because you'll be able to copy a code over to your DS. That's it.
Testimonial: "Thanks soooo much!!! i have another action replay but its broken (onlineinsertareagone) so when my new one started spazzing out i almost went off!Thx!"
SOURCE: Animal Crossing Wild World wont work on my action replay
have the exact same problem with mine, except its not unkown, but the 2 white bars freezing and stuff. what you need to do is restart your AR by turning off the DS and holding start select and some other button then type in the game name and id again. than it should work just fine
SOURCE: when i put my action replay in my dsi it says there is no game.
it must be because the game cartridge is dirty. It happened with me too. First, try to blow out the dust in the action replay and the yellow data part of the game cartridge. Then if that doesn't work when you plug it in, try to wet it. Use rubbing alchohol with a tissue or an alcohol swab and rub the yellow data part of the game cartridge. It's ok, it won't get destroyed. Since data streams can be cleaned without the use of water and using alchohol cleans it. I used it on my Super Monkey Ball Touch & Roll and it was dirty because I didn't use it for a long time. Then, I wiped with an alchohol swab. After that, I put it in my Action Replay and it went to the codes already.
