Question about Nintendo Wii Console
The console is not turning on
It is plugged in and all connections are secure.
    Scholar:
  • 113 Answers
If you are not getting a light on the wii i would suggest first plugging it directly into the wall, in a different side of the house, or worst case you have blown you ac adapter and you need to replace it.
Posted on Feb 25, 2012
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
My xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a...
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
  5. Check the light on the power supply. If this solution worked, your power supply light will be green....
Dec 23, 2010 | Microsoft Xbox 360 Console
What is error # 51330
Error Code: 51330
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings.
Additional information:
  • Using an Actiontec or 2Wire router? The default security key is often found on a sticker located on the router.
  • Security keys are case-sensitive.
  • WEP keys contain numbers 0 through 9, and only letters A through F.
Other suggestions:
  • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
  • The Wii may have detected and set itself to the wrong security type during the initial connection set up. Try creating a new connection file and going through the connection process again (steps), but be sure that when the Wii asks for a security code, the type shown on screen (WEP or WPA) is what your router is set to. If it is different, try a "Manual Setup."
Dec 12, 2010 | Nintendo Wii Console
Wnt turn on
It's very possible that it has just died. Try plugging it into different outlets, and making sure the connection into it is secure. But my best guess is that it's dead.
Jul 29, 2010 | Nintendo Super NES Console
Won't turn on, switches itself off after a few seconds
Check that the main power switch on the system rear is turned on. Check the AC power cord is securely inserted in the system and the electrical outlet. Also check the connecting power cord is not damaged/bent and the connections in the power plug are OK
Mar 11, 2010 | Sony Playstation 3 (PS3) Console
Control has no power
Sorry if this is an obvious question.. but did you plug the console back in firmly and are all the connections secure?
If you can get it to power on again then here is a troubleshooting guide from Nintendo on syncing the wiimotes.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
Nov 21, 2009 | Nintendo Wii Console
Bought dancing stage game for nintendo wii - do not know where to connect the dance mat
Hello. If you have the correct version (people have bought the ps2 version before on accident) here are the directions.
With the console stood upright (with the power button facing you at the top left),
lift the flap on the top of the console. You will find the ports under this flap. Plug your mat into Port #1.
Make sure that your Wii is turned off before plugging in your mat.
Also, make sure the connection is secure to your console.
Then with the game in the Wii, turn on your console.
The mat should be recognized at that point.
I hope this helps!! Good luck and happy gaming!!
Aug 20, 2008 | Nintendo Wii Console
Ps3
Are you trying to connect via Wifi or via a LAN (a cord).
If Wifi, are you sure there is a network? Do you have the network key? A network key is basically a 10+ character gibberish password that you get when you set up a secure wireless network... It is easier to connect to a non-secure network, but no one recommends keeping a non-secure network... because its not secure ;)
If LAN, try plugging the cord into a computer, and seeing if the computer can connect to the LAN. If a computer can connect, I see no reason the PS3 wouldn't be able to. If the computer can't connect, verify the other end of the cord is plugged into your router/wall, and that it is securely seated. If a router, unplug the power for 10 seconds, then plug it back in and try again.
May 06, 2008 | Sony Playstation 3 (PS3) Console
4 Flashing red lights
unplug all cables from the back of the XBOX and then plug them back on (making sure that they are connected) and then power up the 360.
from past experiences, I've only seen the 4 flashing red lights if the AV connection is not secure.
Good luck
Nov 19, 2007 | Microsoft Xbox 360 Console
Nintendo Wii Console Logo
14 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
