Question about Sentry Safe Safe Fire 1.2 cu.ft. Fire-Resistant Biometric E-Lock, CSW3910
Sentry safe phone number
Cant unlock the safe door -- I have the key , the code and the finger print needed for the system.
    New Friend:
Model number G5241-2B Serial number G935465
Posted on Jul 09, 2013
SOURCE: I can't seem to unlock my safe Sentry 1250.
Locksmiths agree sometimes even with the green light the safe’s batteries are not strong enough to retract the latch. Try replacing them with some new alkaline batteries
Posted on Aug 09, 2010
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
SOURCE: sentry safe
need combination and key to model3417 number on side of door Z-463218*
Posted on Jan 29, 2008
dmathwizard
  • 113 Answers
SOURCE: Lost key to sentry safe
You have to contact Sentry directly to get another key
Sentry Safe
1-800-828-1438
www.sentrysafe.com
Posted on Mar 05, 2008
SOURCE: I have a Sentry Fireproof Safe (KS2100). Need to
You are supposed to apply downward pressure on the lid when you try to open it. See if that solves your problem.
Posted on Aug 12, 2010
Brinks Home Security Safes
i think with this kind of safe it comes with 2 keys, one which requires the code to be entered, and a master key that will unlock without requiring the code.
if you have the master key, just use that.
after you have opened the door you can reset the code by pressing the reset button (a pin / paperclip required to press)
on the back of the door.
Feb 15, 2017 | The Computers & Internet
I have forgotten the code to unlock the door
You need a locksmith. They will drill holes in the door to defeat the locking mechanism and then fit you a new door. If there was an easy fix to getting into a safe all the crims would have a lovely easy job. They are not called a 'SAFE' for a reason, the items inside are safe, except for the person who has the key or code.
Dec 02, 2015 | Safe International SentrySafe Home/Office...
Can't get door to lock. I put in code, close the door but it won't lock. Position of key?
Google search your manufacturer make and model and the word manual. If one is available, you can find it in the search results.
Mar 23, 2015 | Home Security
How to close an SW3750 safe (by Sentry Safe)
To close and lock
You can relock the safe in two ways. With the door
closed, depress the key lock (if equipped) with your
finger, or spin the combination dial one full turn.
For greatest security, do both. (Make sure the door
handle is in the horizontal position.) There is a link to the manual at the bottom of this page...
http://www.sentrysafe.com/Products/380/SW3750_Electronic_FIRE-SAFE_
May 17, 2014 | Home Security
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
Remote got wet in salt water. Had battery changed
Programming
When
Key added or replaced. System malfunction.
How
Driver's door open and key removed from ignition switch. Insert key into ignition switch, then remove it. Within 5 seconds: Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch, then remove it. Within 40 seconds: Close and open driver's door twice. Insert key into ignition switch. Close driver's door. Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes. Remove key. System should now lock and unlock vehicle, once or twice depending which mode has been selected. Carry out the following button procedure within 40 seconds: Press key lock or unlock button once. Within 3 seconds: Press same key lock or unlock button once. System should now lock and unlock vehicle.
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat button procedure.
If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Open driver's door. NOTE: A maximum of 4 keys can be programmed
This will work providing printed circuit is not damaged in remote
Jul 20, 2010 | 2004 Toyota Camry
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
I can't open "My Safe"
Hi, did u try starting your system in safe mode?
If not, try starting your system in "Safe Mode", and try re-installing the finger print software.,
Make sure you have the setup file for the finger print reader before you uninstall it from the system
Sep 29, 2009 | Toshiba Satellite A105 Notebook
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Sentry Safe Safe Fire 1.2 cu.ft. Fire-Resistant Biometric E-Lock, CSW3910 Logo
286 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
