Question about Lexmark C544dn Laser Printer
C544dn lexmark memory full
When printing a word document it says memory full 38
ronaldsuboc
  • 449 Answers
SOURCE: lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Posted on Nov 10, 2008
egadgetguy
  • 258 Answers
SOURCE: document color differs from screen color- lexmark z617
Sounds like the print head is clogged. Some models have the head in the cartridge, others don't. Those that do, a cartridge replacement will help, others need cleaning manually. Also, a software head cleaning may be all it needs.
Posted on Jan 01, 2009
SOURCE: Error message: 38 memory full
9XBFLA
Posted on May 20, 2009
xptareq2000
  • 1447 Answers
SOURCE: Our lexmark Z705 printer only prints won't print black.
Clean your printer cartridge printer maintainence program or alignment or head clean
Posted on Jun 28, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: i am trying to print
    Try to clean the print cartridge nozzles. On your computer, go to Start menu > All Programs / Programs > Lexmark Z600 Series > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them. Try to print your document again and to check if print quality is achieved.
    Posted on Aug 02, 2011
    Why does lexmark c544dn print pink spots?
    Probably dropping from Magenta cartridge.Try replacing toner.
    Apr 24, 2014 | Lexmark Office Equipment & Supplies
    I have a Lexmark C544dn printer. I am getting a yellow haze on the right side of all pages printed.
    Check the transfer belt and clean if necessary with Isopropanol (IPA), and a soft clean cloth. Also check the drum for the same. Handle with extreme care as these are fragile and expensive. If none of those fix the issue you may need to get the laser lenses cleaned professionally.
    Sep 09, 2013 | Lexmark C544dn Laser Printer
    Our lexmark c544dn has a paper jam but when I open the front cover I do not see one. What else should I do?
    Pull back the fuser cover ( black upper area) and look for the jam beneath the black roller with paper sticking up - to pull it out
    Aug 05, 2011 | Lexmark C544dn Laser Printer
    I am trying to print and nothing comes out on paper. cartridge black half full and color full and it will not print anything from an open document to a new document with some typing on it. lexmark z600...
    Jul 25, 2011 | Lexmark Z600 InkJet Printer
    C544dn printer - getting code: 941.02 service magenta TMC sensor
    Please try the steps provided below.
    Step Action 1
    Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
    Did the error message return?
    Yes: Continue to Step 2.
    No: The error is resolved. 2
    Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
    Yes: Continue to Step 3.
    No: The error is resolved. 3
    It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
    Did the error message return?Yes: Continue to Contacting Lexmark.
    No: The error is resolved. If the toner and/or developer were not near the end of their working life.
    You can also refer to this link: http://bit.ly/kecjEM
    Jun 07, 2011 | Lexmark C544dn Laser Printer
    Lexmark printer c544dn. The printer is saying to "82 Replace waste toner box"
    Please click on the link http://bit.ly/psOcDA to see instructions on how to go about the procedure.
    For further assistance, please contact Lexmark Technical Support.
    May 10, 2011 | Lexmark C544dn Laser Printer
    When trying to print, says "busy" then it say
    This is a software error within the printer. Contact the manufacturer, as you likely do not have the equipment or expertise to fix this.
    Feb 07, 2011 | Lexmark C544dn Laser Printer
    Error code 900 Lexmark c544dn network printer
    900 errors usually point to fuser or fuser related component failure.
    Please have the printer serviced.
    Oct 06, 2010 | Lexmark C544dn Laser Printer
    you may have some corruption on the power point .
    try printing only one page at a time.
    if it refuses to print a certain page you have found the issue.
    Feb 29, 2008 | Lexmark C510n Laser Printer
    CODE 38 mEMORY FULL
    A laser prints a whole page at a time, some pictures or pdf's require more memory than is installed on a original machine, you can buy additional memory modules to install on your printer which will allow you to print the entire document. I bought two 1 meg modules for about $50 each and have not had a problem since. Check your user manual or the lexmark web site to make sure that you are getting the right memory. The lexmark memory is about half the size of normal computer memory.
    Dec 07, 2007 | Lexmark C510 Laser Printer
    Lexmark C544dn Laser Printer Logo
    102 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
