Question about Kenneth Cole Watches
Kenneth Cole A126-10 KC1619
My watch has stopped working and needs repair. My understanding is that it does not have a battery. How do I fix my watch?
SOURCE: leather watch band
I might have the solution. Is it a rectangular watch with a leather strap? It sounds weird, but I have a watch with no brand name on it (bought yesterday from K-Mart at $9.99) with the model #A126-06. The package insert said "Advance Watch Group." I googled them, and they manufacture watches for Kenneth Cole, Tommy Bahama and a bunch of other designers.
I was really surprised because K-Mart is the last place I'd buy a watch, except that it looked like my broken Raymond Weil tank watch.
I suggest you go to K-Mart and see if you find a watch that looks like yours.
The back of this watch is marked as follows:
V377
Stainless Steel Caseback
2035 Movement
Base Metal
Bezel
20279knx
A126-06
Posted on Aug 10, 2008
SOURCE: Kenneth Cole KC3754
www.genevawatchgroup.com will come up on google, I got it to come up today, 20 Nov. '07 and clicking on the first heading that came up, "geneva Watch Groiup" I got on and was able to print out a repair service sheet for Kenneth Cole
Posted on Nov 21, 2007
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
SOURCE: Kenneth Cole Watch KC3493... getting the back off
sometimes watches must be opened from the crystal side
Posted on Apr 11, 2009
escapement
  • 2334 Answers
SOURCE: How do I replace a battery on a kenneth cole watch
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Posted on Feb 28, 2010
I have a DKNY NY-1251 but i need the instruction to work it because it not working with new batteries. it was working but keeps on stopping
If it is an analog watch and the second hand moves a few time then stops and sort of twitches then the watch battery (even though new) may be bad. If not the the watch is dead and needs repair.
Jul 04, 2016 | DKNY Watches
Frenzy watch #FRZK1103 light up function no longer works, even after replacing battery. Is there a simple fix?
No simple fix, you will need a watch repair shop to fix this, but make sure you get a repair estimate, it may shock you.
Dec 07, 2014 | ACCUTIME WATCH CORP. Frenzy Ladies Watch...
Pulsar solar watch repair, stopped running
They have a rechargeable battery in them,you'll have to go to jeweler or a watch repair store.the battery is not cheap!!! I had my wifes fixed a few years ago the battery cost $68.00,but she likes the watch so it was worth it.
Jan 17, 2013 | Pulsar Watches
L have Anne Klein watch and it stopped working, took it to the repair shop and changed the battery and the repairer told me it uses battery no. 317, it didn't stay long before it stopped working...
look for another watch service center, or bring it to the authorized distributor of your anne klein watch. they have what you are looking for. i hope this will helped you.
Sep 05, 2011 | Watches
We bought the Fossil Brown rectangle watch model FS4284, it stopped working so thought it was the battery. we replaced the battery and then 2 months later it's not working again, faulty battery or is...
  • Change the battery. If your watch stops ticking, chances are the watch is not broken and the battery simply needs to be replaced. You can purchase a watch battery at your local department store or drugstore. Use the screwdriver to pry the back off the watch and place the new battery in the same place where the old one fit.
  • Step 2 If your watch is still not working, determine the problem. If you can hear the watch ticking but the hands are not moving, there may be a gear stuck inside. If only one of the hands does not move, the hand itself could be broken. Once you determine the problem, you can see whether it makes more sense to purchase a new watch or get the old one fixed.
  • Step 3 Check your watch warranty. If your Fossil watch came with a warranty that is not yet expired, Fossil will fix your watch if you send it to the company and pay for shipping and handling. See the "Resources" section below to fill out the Watch Repair Form provided by Fossil.com. If your watch strap is broken, however, Fossil will charge you a fee as broken straps are not covered in the warranty.
  • Step 4 Check a competing local watch repair store. There are watch repair stores located all over the United States that will repair a Fossil watch if your watch is no longer under warranty or if you do not want to pay the shipping and handling to send the watch to Fossil's watch repair department. Although the watch repair store may not have the exact strap you are looking for, it may offer a replacement strap that is similar to the one that originally came with your watch.
  • Step 5 Return the watch to the store where you bought it. If you purchased a Fossil watch that was broken when you purchased it or broke recently after you brought it home, you may be able to return the watch for a refund or store credit. Check with the store's policy before purchasing the watch if you are concerned about returns.
  • Aug 10, 2010 | Fossil Brown Ip Brown Rectangle Ip FS4284...
    The light in my watch stopped working. How do I get it fixed? It is a Timex Indiglo(ladies) I don't have any other info.
    Most watches of this type have 2 batteries - 1 for the light and 1 for timekeeping. If you use the light a lot, you may have flattened the battery but the watch keeps going because it's running on the other battery. Take it to your local jewellers/watchmakers/watch repair shop and get them to test the battery and replace if flat. If the battery isn't flat and the light doesn't work then you have a faulty watch - if it's still under guarantee fine, if not buy yourself another watch if you can't put up with the fault.
    Jul 29, 2010 | Timex 27191 Wristwatch
    Battery? or can any jewlry/watch repair shop fix?
    mcdevito75 here Best Bet, look for a small watch repair shop in yourarea, most likely you need a battery or even better, loosened the one already in the watch.
    Jul 02, 2010 | Freestyle SDI I Wrist Watch
    Have old Mickey Mouse self winding watch. Bought
    I will explain from the last question asked. To get it going you have to visit your nearest watch repair shop and ask for estimate. Shop owner told you things he/she do not understand at all - self winding watches CAN NOT BE OVERWOUND, so, there is the question: are you sure this watch is self winding? I've experience of 26 years of watchmaking and have never came across Mickey Mouse watches having self winding movements. As far as I know, all MM watches are battery driven, but in case if you really have the mechanical one - you are lucky. That means there were past times when those watches were fitted with mechanical movements and now they are rarities. Even if your watch is not self winding, but is mechanical (not battery driven), visit your nearest watch repair shop and ask to check this watch out. In case if it is mechanical - pay the money and get it fixed (you will be a winner anyway). If it is battery driven - put it on your shelf where your's mother in law picture is and treat it accordingly. Rate me , plz.
    Feb 18, 2010 | Disney Watches
    New quartz analogue watch losing 5 minutes a day.
    not often so . beleive you me from an avid fine watch collector . it's the batteries. hopt this helps.
    Jan 24, 2010 | Timex 27191 Wristwatch
    Citzen eco drive watch stopped when i changed time
    Try to find solution here:
    http://www.citizenwatch.com/COA/English/settings.asp
    Interactive settings are very helpfull as well.
    Rate, please.
    Mar 30, 2009 | Citizen Watches
    Watches Logo
    563 people viewed this question
    Top Kenneth Cole Watches Experts
    Jimmy Accardi
    Ansel Alberto
    Ansel Alberto
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
