Question about LG Computers & Internet
My LG monitor model W2361VV won't stay on
The monitor won't stay on when the power is turned on
budmrtn
  • 11361 Answers
SOURCE: LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 26, 2010
budmrtn
  • 11361 Answers
SOURCE: I have several of these monitors that won't
It can be as simple as bad caps, or worst case will be bad lamp assembly.
http://s807.photobucket.com/albums/yy352/budm/HP/HP%20L1706/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on May 09, 2011
  • 661 Answers
SOURCE: LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
Posted on May 12, 2011
Slasher_X
  • 767 Answers
SOURCE: My flatron lg monitor goes
See my tip here: http://www.fixya.com/support/r6820093-hard_drive_or_monitor_randomly_switching
Posted on May 31, 2011
SOURCE: lcd-17v8 monitor power won't stay
If the monitor turns on and goes directly to sleep, or it powers on briefly and shows an image then goes black then the monitor is defective. The first is often an I/O panel issue inside of the monitor. The second is typically a lamp failure within the monitor.
A simple test would be to plug a different monitor into your computer or this monitor into another computer. If the monitor doesn't work on another computer or a different monitor works on the same computer then the monitor is the issue.
If the different monitor does not work on the same computer or this monitor does work on a different computer then something on the computer is to be suspected such as a driver issue or a faulty video card.
If you find the monitor is defective then you should dispose of it (assuming it is not under warranty) at a nearby recycling center and purchase a new monitor. I would suggest something by Acer, Samsung, Dell, HP, NEC, or Viewsonic. These brands cost a bit more, but have much better track records.
Posted on Sep 06, 2011
HP LE1901W won't stay lit up
usually with lcds, this can be caused by a bad inverter or power supply
Jun 20, 2012 | HP L1710 LCD Monitor
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
LG Monitor won't turn on
I had this same problem with mine, and had to replace it. Sometimes it's the power supply, but depending on how old it is and how much it's been used, usually unlikely.
If you have a way to check the power supply output for proper current and voltage, and it appears to be fine then that's eliminated as a possibility.
Typically, time to replace it, unfortunately.
I hope this helps!
Feb 13, 2012 | LG Computers & Internet
Connecting - flashes 3 times - picture & sound come on - flashes 2 times and turns off - won't stay on
COULD BE A SHORT IN THE POWER SUPPLY IF YOU ARE NOT A TECH THEN HAVE A TECH REPAIR YOUR TV.GOOD LUCK.
Oct 06, 2011 | LG 42LC2D 42 in. LCD HDTV
My LG Flatron W2453SQ monitor is connected to my laptop. Since two days ago, when I dont touch the keyboard/mouse for 30 secs the monitor goes blank and enteres power saving mode. I have chyecked the cable...
HI kissakiwi,
In the control panel's power option , you need to change the SYTEM STANDBY settings to never , and then the problem would be solved.
There are three options , turn of monitor, turn of hard disk and , system standby , if you select all of these three to 'never' then you won't have this problem.
Remember you can also change the settings via the screen saver tab when you right click and select properties on the desktop.
Let me know in case you have any queries. Hope this helps ...:)
Jul 01, 2011 | LG 22" FLATRON LCD Monitor
Hi Anand,
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
LG W2452v - Monitor turns on and off every 5 minuites...
I solved the problem by not using the DVI cable. I used the D-Sub cable. If your pc does not have D-sub connector then use an adaptor. I not only solved the problem but got the full 1920 x 1200 resolution
Mar 05, 2009 | LG Flatron L2320A 23" LCD Monitor
Computers & Internet Logo
113 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
