Question about Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater
My Comfort Zone Utility/portable infrared heater, model CZ1500-WO is displaying an AOS error code and will not turn on. What does that mean and can it be repaired?
  • seashell518
    seashell518 Oct 18, 2012
    I sent my circuit board to Lee Kreuzer (see his note below) and he repaired it and mailed it back quickly, only cost $45. He will tell u how to remove the circuit board, quite easily done.
  • KD Grayson Heating,Air conditioning & Refrigeration
    Add aComfort Zone CZ2011P Infrared Quartz Space Heater - Heats up to 1000 sqr/ft Comment
If the relays are clicking there is 2 1000 uf capacitors on the board that if looked at from the side they will be domed they are bad. Replace and the problem is solved.
Posted on Jan 11, 2013
  • Ed Weekes Sr.
    Ed Weekes Sr. Nov 10, 2013
    $3 for 2 capacitors at Radio Shack and about 30 minutes total saved an $87 board, even repaired the first 1 for a back-up at that price
    Problem Solver:
  • 13 Answers
The control board needs to be repaired. You can get in contact with me at leekreuzer@yahoo.com.
Posted on Mar 08, 2012
  • 499 Answers
Any electric heat thats not a heat pump, is 100% efficient converting 1 Watt into BTU's or 1 Watt = 3.145 BTu's.
Only a heat pump can offer you more heat per watt.Consequently any inexpensive heater will replace that unit! and for far less than the labor to even diagnose that thing, let alone parts avaiability! I would not repair it or try unles as a DIY job for kicks.
Posted on Feb 25, 2012
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Posted on Oct 14, 2008
emissionwiz
  • 76070 Answers
SOURCE: I have an AO5 error
what is A05
Posted on Sep 10, 2010
SOURCE: My comfort zone infrared hearter
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Posted on Nov 24, 2010
luxfargo
  • 14 Answers
SOURCE: i need 2 heating elemements
You can order them from True Green 800-595-9605
Posted on Dec 03, 2011
  • 4736 Answers
SOURCE: I have a comfort zone
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Posted on Jan 20, 2011
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Where can i order a new board for my comfort zone cz1500 the board is bad showing aos code.
It's probably some swolen electrolytic capacitors that need replacing. If you know of an electronic shop close by or buddy that can solder maybe you can remove the pcb and take it to them. Radio Shack may stock the caps.
Jan 15, 2015 | Comfort Zone CZ1500WC Infra-Red...
I just got a life smart infrared heater took it out of the box plugged it in and turned it on and an E3 code is flashing wont turn on or any thing
What is wrong with my Comfort furnace, If it will not turn of when i push the off butting ?And even after that i unplug it and turn it back on ,it still comes on and will not go of like it use to with the temp control !!
Nov 30, 2013 | Comfort Zone CZ1500WC Infra-Red...
Error code AOS
its show flashing AO5 code and than shut off
Nov 18, 2013 | Comfort Zone CZ1500WC Infra-Red...
Flashing AO5
if the relays are clicking there are 2 1000uf capacitors on the main board that will be bad. If you know how to work on electronics you can unsolder and then replace them problem solved I just fixed my dads heater today cost about 2.00 bucks :). The capacitors have to be 1000uf 105c google them.
Jan 04, 2013 | Comfort Zone CZ1500WC Infra-Red...
Why does my comfort zone infrared heater shut off after I turn it on? What modes does it have?
What is wrong with my Comfort Furnace heater if i have it turned off and it still keeps blowing ,Yet if i plug it back in it still comes on and i can turn it way down with it down on 55 and it will not shut of like it use to?
Oct 08, 2012 | Comfort Zone CZ1500WC Infra-Red...
Settings on my CZ 1500
To switch between C and F, hold DOWN and ENTER for three seconds.
( I sell these. )
Mar 11, 2009 | Comfort Zone NEW 09 Electric Portable...
Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater Logo
2,624 people viewed this question
Top Comfort Zone Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
