Question about Sony Playstation 3 (PS3) Console
HOW DO I CHANGE MY PS3 NAT TYPE - Sony Playstation 3 (PS3) Console
  • Sony Master
  • 32,281 Answers
Instructions for PlayStation NAT settings are on this WEB site.
http://manuals.playstation.net/document/en/ps3/current/settings/connecttest.html
Posted on Feb 25, 2012
Chadha Saab
  • 142 Answers
SOURCE: My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Posted on Feb 18, 2008
Tom Marvolo
  • 708 Answers
SOURCE: how do you change nat
First Disable the Firewall on your Router
Then Open the Following ports For your PS3 ( The Interface given is of a belkin Router ) (The IP Address of the PS3 Might be different )
And also make sure UPnP is Enabled
Posted on Aug 20, 2010
Tom Marvolo
  • 708 Answers
SOURCE: nat problems
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Tom Marvolo
  • 708 Answers
SOURCE: i got nat type 2 on my ps3 internet test,but wen i
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Posted on Sep 26, 2010
Pensivecoder
  • 86 Answers
SOURCE: How to change your NAT
When your console talks about a NAT problem it isnt referring to itself but rather to your router, Log in to your routers web management console, normally works by typing 192.168.1.1 and then entering admin for username as well as password when the login dialog comes up, oor leave the username blank and enter admin for password, from there go to WAN configuration and look for NAT Type or check under advanced routing, just change it from whatever setting its on to the alternate and save your configuration, VOILA... Hpe this helps
Posted on Oct 27, 2010
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
I can't change the nat type for ps3 or call of duty black ops how do i change the nat type
When you do a connection test on your PS3, what NAT type shows up; 1, 2, or 3. If you're worried about the STRICT NAT type in Black Ops, don't worry about it, the problem is the game and not your router.
http://forums.dlink.com/index.php?action=printpage;topic=21218.0
Feb 06, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I whant open in ps3
I take it that you want to change NAT type in your PS3. To open NAT type you first need to get port numbers from PS3 people. Once you get the ports check what the IP add on the PS3 is.Once you have this information login to the router interface and punch in the port numbers and the IP add and your NAT type should be open.
Hope this helped.
Jan 23, 2011 | LanTech (HR-114 II) Router
How do you open nat type on the ps3 ?
Nat type is actually defined by your isp..(internet service provider) some companies do not actually support gaming and therefore their service is considered "strict" by ps3 standards for multiplayer gaming online. You may have to reconfigure your pc internet security settings on the computer itself...possibly logging into your router/modem. If this is not helpful or u are unsure of how to do this, contact your isp and explain to them you want the nat type changed...basically they will either not be able to at all and then u need a new isp or they can do it in a matter of minutes and ur nat type will change and give u full access to ps3 online within a matter of hours...hope it helps and u get back to gaming!
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
Change nat type
To reduce the NAT
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
Nat type changes back on ps3
you need to make sure that when you change it that you apply in your modem setup page that bridge mode is activated so that it turns it into a dumb unit allowing just to pass through the internet stream thus allowing constant nat 2 connection
Feb 05, 2009 | Zyxel P660HW-D1 Router
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
Sony Playstation 3 (PS3) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
