Question about Texas Instruments TI-34II Explorer Plus Calculator
Add mixed numbers
How do I add mixed numbers?
  • Anonymous Mar 03, 2009
    how do i add mixed numbers
  • Anonymous Mar 13, 2014
    Add mixed numbers write in simplest form
  • Texas Instru... Master
  • 8,016 Answers
This image shows you on the quick guide where you can find the information.
Once you know how to interpret the results, you can add the mixed numbers as you would ordinary numbers.
Hope it helps.
Posted on Sep 22, 2009
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
How to divide 1 2/3 by 3
First make 1 2/3 into a mixed fraction and then divide it by 3.
To make 1 2/3 into a mixed fraction, multiply the whole number, in this case, 1, by the denominator (the bottom number) and then add the numerator (the top number). Thus, we get (1*3+2)/3 or 5/3. Now we have to take 5/3 and divide it by 3. I was taught that in this case, dividing by 3 is the same as multiplying by 1/3. 5/3 x 1/3 = 5/9.
If you have access to a calculator you can always check this. On the calculator, do 2 divided by 3 and add 1. Now take that answer and divide by 3. Write down this answer. Now take 5 and divide by 9. Write down this answer. They should be the same.
Good luck.
Paul
Mar 17, 2015 | Office Equipment & Supplies
Need instructions for DQ Blizzard Maker
1st add crushed ice and equal water outside the tin in the blizzard
2nd add 3/4 of salt to the the salt water
3rd put the cap on and in a separate cup mix ice cream mix and 3/4 of half and half and mix until completely dissolved
4th put the mix in the tin cup and add the cap
5th stir with flat spinner not the swirly one spin for 10 min when done push ice cream with swirly stirrer
Nov 01, 2013 | Spin Master 1001130 DQ BLIZZARD MAKER
Mixed numbers
If the result is positive, type in the integer part then add the fraction part either with the help of the fraction key or the division key. (I do not think that the TI82 has a fraction key.
If it is anything like the TI3 there is command under MATH >Frac. It should be pressed after you enter the mixed number to keep the result as a fraction.
If the mixed number is negative you enclose the whole number in parentheses. Press the change sign (-) key to negate the result.
Sep 26, 2012 | Texas Instruments TI-82 Calculator
Do I mix the oil and gas together and pour it in the gas tank or do I pour the gas in the tank and the waverunner mix's the oil and gas together?
Mix the oil and gas together first.
Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
Jun 24, 2012 | Boating
I have a mitsubishi lancer 2002. The coolant reservoir tank is empty. Radiator is full. I just need to add coolant to reservoir. Do i add straight coolant or does it need to be a 50/50 water/coolant mix?
It is best to add a coolant mix. You can get it ready mixed, but try to ascertain if your car now has in it green mix or red mix. It is best not to mix these 2 mixes LOL
If you cannot make out what is in there now, just add demineralised water.
Dec 14, 2011 | 2002 Mitsubishi Lancer
How do you enter mixed numbers ( whole numbers and fractions i.e 3 3/4)?
You cannot, you must enter 3.75. If you can't figure out what the fraction is, you must first compute the fraction (3/4=.75) and then add it to the whole number (3+.75=3.75)
Sep 15, 2011 | Office Equipment & Supplies
My son lost the directions to his Disney cupcake mix from Walgreens. Do you have ingredients and instructions?
I have directions for you. They are 1 cake mix, 2 eggs and 4 tsps butter. blend cake mix with eggs for 30 sec. add butter and beat 3-4 min. Bake 350 for 10-12 min.
Frosting: Add 2 TBLSP of boiling water. beat on high for 2 min. If it is too thick add little water or if too thin, but in refrigerator for 10 min. and mix.
Hope that helps.
Jan 05, 2011 | Toys
I have a Black and Dekker all-in-one Breadmaker B2200. The manual has very few recipes so I often use the recipes from my previous Breadmaker B1650. It had an Add Ingredients alert (to let you add nuts...
NO, it;s better to wait until kneading has started. If it has a second kneading add then. If not, add in a few minutes after ingredients have started mixing. Just lift the lid and drop them in as it mixes.
Jun 23, 2017 | Black & Decker B2000 Bread Maker
write the mixed number as a sum of a whole number and a fraction
example: 2 1/3 type in 2 + (1/3) and you'll have no problems
Mar 24, 2010 | Texas Instruments TI-34II Explorer Plus...
Texas Instruments TI-34II Explorer Plus Calculator Logo
361 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
