Question about Lands Phones
How to program numbers into a n AT&T speaker phone - #952
3 Suggested Answers
  • 7993 Answers
SOURCE: where is the 2nd F
The key is called SHIFT on Casio calculators. To get the arcsine of an angle you press [SHIFT][SIN], then enter the angle measure in the appropriate unit (degree in your case) and press ENTER. Your result should be 15.01073397 or 15, to nearest degree.
Posted on Sep 06, 2010
  • 1575 Answers
SOURCE: manual for a 952 AT&T speaker phone
Hi
Download the manual from the link below.
www.orficn.net/Verizon Website/Phone Manuals/ATT Model952 Manual.pdf
Hope it helps.Thanks
Posted on Feb 25, 2012
The width and hieght of a tv screen which is 16:9 need to find the diagnol if it is 98 cm wide
.98/16 * 9 = .55125m = height tan? = .55125 / .98 ? = 29.357 cos ? = .98 / x x = .98 / cos ? x = 1.1244 m
May 17, 2011 | Office Equipment & Supplies
Where is the 2nd F key, to find the size of θ (to the nearest degree) where θ is acute. example question: sin θ = 0·259
Sep 05, 2010 | Casio FX-115ES Scientific Calculator
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
I have an older at&t 620 speaker phone
goto call settings and fix in the numbers you want for speed dial
Jul 15, 2009 | Lands Phones
Laptop dv9000
What are these codes can you please explain inorder for me to help you out...
Jul 11, 2009 | Computers & Internet
Quardartic equation
try change the phone or try reflashing it
Aug 22, 2008 | Nokia 6233 Cellular Phone
Format N95
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
Billman87
Nov 16, 2007 | Nokia N95 Cellular Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
