Question about GPS
Charge the battery isnt charging either ac or dc
How do you change the date on tom tom 720?
Posted on Jan 17, 2009
Why would my 120 converter not keep my batteries charged while plugged in?
If you are referring to a 12V DC - to -120V AC converter, then the answer is obvious. The converter makes the AC from the DC voltage provided by the batteries. You cannot charge a DC battery with an AC source. Additionally, even if you could, the resulting charge would be less than the draw taken from the battery (physics - loss from heat). Also, there wouldn't be enough power left over to do anything with.
Nov 23, 2014 | Cars & Trucks
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
Why wont my hp pavillion dv7-1240us turn on with or without being plugged in ? but while plugged in if i hit the power button all the upper lights breifly come on then off..
because the battery isnt charging. Most likely cause is your dc jack is broken. Take out the battery, plug in AC adapter. Gently wiggle the adapter and hit the power repeatly. If it briefly turns on and off then yes your DC jack needs to be re-soldered.
Aug 16, 2012 | HP Pavilion dv7-1245dx Notebook
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Honda Accord 1989 part that converts ac to dc
The alternator.
It should produce 13.5-14.6 volts DC when charging a 12V battery
Jan 07, 2009 | 1989 Honda Accord 4 Door
Battery is not charging
Charger board seems to have gone bad.
Aug 05, 2008 | HP NC4010 Notebook
Compaq Presario 1200 won't charge battery
dear N9YK
you can follow this
If you have a loose connection where you plug in the power on your laptop, or it works intermittently, you could have a bad dc jack. Symptoms
  • Move the power plug and the laptop loses connection
  • Broken or cracked dc jack
  • Laptop won't charge but worked on battery
  • Power LED and battery LED flicker when the adapter tip is moved
  • Battery won't charge
  • Sparks come out the back of the laptop
Why does this happen?
  • Flaw in manufacturer designs
  • Use of universal or non-original ac adapter
  • Lots of plugging and unplugging of the ac adapter
  • Tripping on or pulling the ac adapter cord
or you can check your dc amper in your adaptor
oke
thx
cropp
Mar 16, 2008 | Compaq Presario 1200 Notebook
I can't charge the battary.
Disconnect DC power cable from AC adapter/charger. Battery charging will not be possible if the DC power cable is left connected to the AC adapter/charger.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
GPS Logo
188 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
