Question about Motorola Mobility AT&T Prepaid Free2Go Wireless Phone Kit
Manual for a 952 AT&T speaker phone
How to program numbers in unit
    Top Expert:
  • 1,575 Answers
Hi
Download the manual from the link below.
www.orficn.net/Verizon Website/Phone Manuals/ATT Model952 Manual.pdf
Hope it helps.Thanks
Posted on Feb 25, 2012
The width and hieght of a tv screen which is 16:9 need to find the diagnol if it is 98 cm wide
.98/16 * 9 = .55125m = height tan? = .55125 / .98 ? = 29.357 cos ? = .98 / x x = .98 / cos ? x = 1.1244 m
May 17, 2011 | Office Equipment & Supplies
Inoperative SS5 Speakers
so what is happening now?
are the speakers not functioning completely?
Oct 02, 2008 | Nakamichi SoundSpace 5 Shelf System
Where is the 2nd F key, to find the size of θ (to the nearest degree) where θ is acute. example question: sin θ = 0·259
The key is called SHIFT on Casio calculators. To get the arcsine of an angle you press [SHIFT][SIN], then enter the angle measure in the appropriate unit (degree in your case) and press ENTER. Your result should be 15.01073397 or 15, to nearest degree.
Sep 05, 2010 | Casio FX-115ES Scientific Calculator
How do you use the pol and rec
To avoid errors make sure that the angle unit is THE ONE required by your problem. To verify or to change the angle unit press [SIFT][MODE] and select [3: Deg] for degrees, [4:Rad] for radians, or [5:Grad] for grads.
Convert from rectangular to polar
[SHIFT][+] (Pol) . Screen displays Pol(
You enter the X-coordinate, and the Y coordinate separated by a comma, then you close the parenthesis and press [=].
Exemple: Polar coordinate of the point (1,1)
Pol( 1, 1) gives
r=1.414213562 (square root of 2)
θ=45
Here is how you enter it
Press [SHIFT][MODE][2:LineIO]
[SHIFT][POL] 1 [SHIF] [,] 1 [)] [=]
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
Convert from polar to rectangular coordinates
Rec ( radius, angle) =
Exemple: Recatngular coordinates of (r=3, θ=60°)
[SHIFT][Rec] 3 [SHIFT][,] 60 [ ) ] [=]
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Jan 19, 2010 | Casio FX-115ES Scientific Calculator
Can you show how to convert pola to rectangular o
Pol( 1, 1) gives
θ=45
The screen displays
Pol(1,1)
r= 1.414213562
θ= 45
The screen displays
Rec(3,60)
X= 1.5
Y= 2.598076211
Hope it helps.
Nov 14, 2009 | Casio FX-115ES Scientific Calculator
Panasonic KX-TG2583. How do I change the time?
TIME/DATE ADJUSTMENT:
Press Function/Exit/Ch on the handset.
Press the up & down arrow keys until it points to 'program'
Press the Fwd/Edit > (yes key)
Press the up & down arrow keys until it points to 'tad program'
Press the Fwd/Edit > (yes key) the base unit will now display programming opitons.
Press '0'...'set time' is announced
Enter the time (hour & minute) using a 4-digit number
(Ex. To set 9:30 enter 0930)
Press * to select AM or PM
Press # repeatedly to set the day.
SELECTING THE NUMBER OF RINGS:
Press '2'...the current setting is displayed on the base unit
Press 0 or 2 or 7 to set the number of rings
(0='Toll Saver, 2=Two rings, 7=Seven rings)
Press Fwd/Edit (save key) a beep will sound
To return to normal mode press Function/Exit/Ch
I HOPE THIS HELPS! I copied it from my phone manual!
Best of luck!
Emma
Jul 22, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
I have an older at&t 620 speaker phone
goto call settings and fix in the numbers you want for speed dial
Jul 15, 2009 | Lands Phones
Missing owners manual
PDF file from the Motorola site for the L6 phone - Here!
Lemme know if this helped!
Jan 05, 2009 | Motorola Mobility L6 Cellular Phone
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Motorola Mobility AT&T Prepaid Free2Go Wireless Phone Kit Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
