Question about IBM ThinkCentre M50 PC Desktop
IBM embedded security sub system
I installed a new hard drive. I cannot get the system to post due to a cover switch for the security sub system. How can I bypass this feature.
  • Joe Serrano Feb 26, 2012
    IBM Thinkcentre M50. The motherboard part number is 19R2563. The system worked fine. I replaced the CD drive because it was defective. Now when I try to boot up the system it will not even post. It powers up, that is the fans start and power light are on. TRhe scrren is black with no posting whatsoever. There is a switch that gets triggered when you remove the cover of the pc. This switch is connected to a small daughter board known as a POV daughter board part number 25P5079. I suspect this is some kind of security feature. My problem is I cannot even get into CMOS. The system will not post. I cannot find any info on this feature, Please help really desperate here.
  • 62 Answers
Is this a laptop?
if so tape down the cover switch (this is a mini switch on the mainboard)
Posted on Feb 25, 2012
2 Suggested Answers
kornho
  • 781 Answers
SOURCE: CMOS Error 0193
I'm doing some research on your behalf and the hits I'm getting what seems to be an item that at some point was attached to the motherboard, that item being a RF antenna, and that know has been removed.
try this:
1. enter BIOS Setup Utility by entering the supervisor password (if one is enable), and select:
  1. Password
  2. Security Chip
  3. Clear Security Chip
  4. exit saving settings
  5. restart
2. try replacing the battery of your motherboard, watch for ESD by grounding yourself by touching the powersupply first before touching any component inside your pc.
3. if 1 or 2 did not work, try to restore your bios to defaults or check on your motherboard what could be missing and if possible disable this item or device then save then exit... if that does not work you may need to replaced the motherboard (sorry)!
Posted on Oct 12, 2008
0912:system security ibm embedded security hardware tamper detected.error system halted
There is a switch in the machine that gtracks if the case has been opened. Alkl you have to do it to run the setup, by entering the BIOS setup routine.
Feb 09, 2015 | IBM Computers & Internet
IBM THINK PAD LENOVA embedded security chip
Sometimes (rarely) laptops need a bit of a kick to get them going! When confronted with this particular issue, I power off the laptop, disconnect the power supply, remove the battery and discharge any residual charge by pressing the power on switch for a couple of seconds.
Replace the battery, re-attach the power and reattempt the normal power on cycle. See it that kicks it into action!
Dec 28, 2013 | IBM ThinkPad Computers & Internet
I can't load any OS on an IBM Thinkpad
Since both operating systems are failing to install, I would suspect that there is a problem with the installation of the harddisk (cable not securely connected) or the new harddisk is faulty.
Dec 08, 2009 | IBM Thinkpad I1400 I1500 2611
Put new hard drive in ibm 570
you need to install the windows operating system to the new hard drive and transfer your files ...
if you still have the CD installer that comes with it when you bought the computer..use the CD with label operating system..then after you install the windows..use the cd with label drivers and application
Mar 15, 2009 | IBM Computers & Internet
Hard drive not found
Wayneard is correct. When you install a brand new hard drive as the ONLY hard drive in the computer, there is no operating system loaded. The computer will try to boot from the hard drive and stop. Switch your boot order to have the CD boot first, and be sure you have the operating system installation CD in your CD drive.
Also, double check your hard drive connections. Be sure it is in the "master" position on the hard drive cable. If there is a connection problem, the system will complain after CD start that there is no hard drive available to install the operating system on!
Good luck.
Dec 30, 2008 | IBM NetVista PC Desktop
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
CMOS erroe 0193
Remove the CMOS battery and also the jumper on the motherboard to reset the bios.
Oct 12, 2008 | IBM NetVista PC Desktop
Password reset for IBM A21m
This generally indicates a failed hard drive, or on occasion, a failed motherboard component. Try reformatting the hard drive and installing a new operating system. If the drive will not format, using a full NTFS format, not the quick format, then the drive has failed and will need replaced. If the machine won't allow you to get to the boot menu to do the format/install, then the security chip on the motherboard has malfunctioned. Unfortunately, the security chip will be an issue that you will either have to send it to IBM to have fixed, or replace the motherboard.
Aug 09, 2008 | Computers & Internet
Hard drive
Hard disk drive buying tips and help Each IBM computer has the availability for a maximum of four IDE devices, ... To install a SCSI hard disk drive you must have a SCSI card and an available
Good Luck.........Please dont for get to Vote.Thank You.
Dec 15, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkCentre M50 PC Desktop Logo
110 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
