Question about Car Audio & Video
How do I connect i pod to panasonic RX DT610
There is no switch for aux. I tried connecting to RCA ports in back; no luck. I tried connecting to headphone jack; no luck. I don't know how to tell panasonic that this is an auxiliary product.
5 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
mixmaster
  • 626 Answers
SOURCE: switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Posted on Nov 12, 2007
SOURCE: does it have a front aux jack on the face plate
nope, it has it on the back
Posted on Jul 20, 2008
zenglish87
  • 5 Answers
SOURCE: jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Posted on Feb 01, 2009
Have an Panasonic Suround System SC-HT70.Want to connect i-pod classic. What do i need?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-HT70-Home-Theater-Systems-manual/id/354ag305/t/2/
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
In your case that would be something like Aux or VCR Audio (In) (page 39).
Jun 22, 2011 | Panasonic Home Theater System System
Hook up an iPod to Beosound2000 system??
There is an Aux input on the B & O. you can connect the I-pod to through this input. You will need a 3.5mm phono to 2 RCA cable connector. The phono jack goes to the I-pods headphone socket and the RCA ( Red & White ) jacks goes to the B & O Aux input.bobhifi_28.jpg
Apr 01, 2011 | Audio Players & Recorders
Can I connect a Sony DVD Player DVP-SR90 to the Panasonic Home Theatre SC-HT75 to achieve surround sound without direct SCART connection - and how?
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
Mar 14, 2011 | Panasonic SC-HT75 System
Panasonic rx-dt610 the speaker port at the back
A port is only an opening into the speaker enclosure. If "it is not working" it is obstructed, something blocking it.
Apr 11, 2010 | Audio Players & Recorders
I dont know how to connect the wii to my rx-465 receiver.
The Wii AV cable should have a red/white pair of Audio Output jacks on it.
Check out pg. 8 of the Wii manual: http://www.nintendo.com/consumer/downloads/WiiOpMn_setup.pdf
Connect the red/white RCA plugs from the AV cable to a line level audio input on your receiver. If you use AUX IN, then select AUX IN on the INPUT selector switch. You should then hear the sound from the Wii through your receiver/home theater system.
Mar 11, 2010 | Yamaha RX-V463 Receiver
How do i hook up an ipod to the rx v596
If you get a dock and a 3.5mm plug to two RCA phono plugs lead, it will then connect to any spare aux imput socket. At the same time the dock will keep the battery in the i-pod charged. Or you can just plug the same lead into the headphone output of the i-pod, but the battery will run down.
Feb 28, 2010 | Yamaha RX-V596 Receiver
How do you hook up your ipod through the rca cable hookups in the back without the radio still playing?
This is different on every stereo, but generally the RCA ports in the back of the stereo are labeled "Aux" or something to that extent.
First, you must purchase a headphone jack to RCA cable which can connect to both your stereo and your ipod.
Connect the cable, turn your ipod on and start playing a song. Turn the volume on the stereo to a moderate volume so you can hear when the song is being played through your stereo. Then, using the selector switch, turn the stereo from "Radio" to "Aux" or whatever it says next to the the RCA plug ins on the back.
Aug 14, 2009 | Pioneer DEH-2000 CD Changer
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
Connecting ipod
Yes you can connect your i-pod to your sa-ht 930. You can buy a connection at Walmart for $5 bucks or you can go to Tareget and buy a monster connection for about $25 bucks. I bought the monster connection and works great. All you have to do is connect it to the AUX in the back to the white and red jack in put. Once you connect it change the input selector to AUX and you're ready to go.
Dec 08, 2007 | Panasonic sa-ht930 Home Theater Audio...
Car Audio & Video Logo
141 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
