Error sc 571
How do I clear the error code sc 571
I did emty the oil from the defuser unit
Thanks,
Paul
  • 161 Answers
There is too much oil in the fuser tank(there should be little oil)
SC 571
• Defective oil end sensor
• Defective oil overflow sensor
• Defective sensor cable
• Oil supply unit not installed
you need to enter the service mode to clear the error(service tech only)
Posted on May 08, 2009
Sc 558 error code on Ricoh Pro C720
That is an oil supply pump error for the fuser. It probably needs to be replaced.
Jan 29, 2015 | Ricoh Office Equipment & Supplies
SC558 is a Oil supply motor error The machine detects a motor rotation error for 5 seconds after the oil
supply motor has rotated for 5 seconds. ?? Oil supply motor defective
?? Oil supply unit defective
1. Replace the oil supply motor.
2. Replace the oil supply unit.
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
Machine showing sc 571
Check the fusing oil unit most likeley something wrong with that. if its new check to see that all the wrappings have been completely removed. ~~> Defective oil end sensor, Defective oil overflow sensor, Defective sensor cable, Oil supply unit not installed
Dec 16, 2009 | Ricoh Aficio 1232C Color Copier
Dsc232 code 571 how to reset
Error code 571 is for oil overflow sensor error.If you pull out fusing unit,on the left side of it there is an oil unit attached,that has oil sensor on it.Most common problem is the sensor is getting disconnected.After you checked the sensor connection,here the procedure to reset the error code:
Turn main power switch off and back on.Then press "clear modes" key, 107 and press and hold "Stop" key for until you see screen has changed. Touch "Copy SP" tab on the screen, the press 5810 and # key. Press "Execute" tab on the screen to reset fusing error code.After that turn the main power to the machine off for a few minutes.Turn the machine back on - the error code should be gone and the machine should be working now.
Oct 05, 2009 | Gestetner DSc232 Copier
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
Aficio 1224c copier sc 571
SC 571 is a fusing error caused by not being seated properly or the oil sensor is coated with oil.
More than likely when the machine was move oil coated the senor in the fuser and it has to be taken apart to be cleaned.
Sep 22, 2008 | Office Equipment & Supplies
Problem with copier Rex Rotary DSc232
571 A Fusing oil overflow
• The oil overflow sensor detects oil.
• When the machine covers are
closed, the oil supply unit is not
detected.
closed, the fusing unit is not
detected.
Possible causes :
Jul 08, 2008 | Office Equipment & Supplies
474 people viewed this question
jasbo
jasbo
