Question about Grilling
CHEF Baroness Integra Electric Oven
I currently have a CHEF Baroness Integra Electric Oven and Grill which is approx 15 years old. I want to replace it with a new CHEF Wall Oven and Grill e.g. model EXC627. However it seems that all the latest CHEF models are 888mm in height whereas my current model is approx 918mm in height. This will no doubt leave a gap at the top when its's fitted. Do CHEF or any other manufacturer have models that are approx 920mm in height or can they be adjusted to fit the gap?
bulldogchief
  • 388 Answers
SOURCE: i have an older Genesis grill with a leaking regulator
You can get a replacement regulator at just about any home improvement store (Home Depot, Lowe's, etc.) There haven't been changes in the size of the ports or thread patterns on regulators or propane tanks in the last 15 years.
Posted on Oct 07, 2009
Testimonial: "Thanks, I went to Ace and saw the regulators male connector and it was nothing like what I have to fit the propane tank so that drove my question."
cadesertmax
  • 274 Answers
SOURCE: Sear knob will not stay on (very loose fit).
Pull the knob of of the sear burner valve shaft and check to see if it is melted on the inside, if it is, it will fit loose and needs to be replaced.
Posted on Jan 10, 2010
jyackle5
  • 8197 Answers
SOURCE: How much current (amperage) does this grill draw?
Yes the 15 amp breaker will work. But a 20 amp would be better.
Posted on Apr 13, 2010
Testimonial: "Very appreciative for the assistance"
SOURCE: install a baroness integra wall oven
I have just brought a house and the oven is a baroness integra gas fan oven - i get the thing ignited as can see the flames but when i gently release the nosel the flames go and there is no heat. it is a little warm but i think that's just from the lamp. Any help would be great - i miss baking!:-(
Posted on May 04, 2010
  • 54 Answers
SOURCE: sunbeam model #650 heat tent
There seems to be 2 sizes 25-5/16x8-1/4 or 27-11/16x8-1/4 heres were you can get them http://www.grillstuff.com/gas-grill-flavorizer-bars/?cat=50
Posted on May 20, 2010
I need to replace my 1987 approx. Chef wall oven Balmain fan forced and grill. Does anyone know the cut out dimensions. I want to buy anew oven that will fit the existing opening. Thanks
when you buy the ovens replacement
instructions are given in the paper work how to adjust the cavity to suit
there will have to be an air gap on back and sides of the new oven
you should call an electrician to wire in the new oven
to check , even replace the 1987 wiring and connections
if needed to meet the 2016 house wiring standards
you will need
tape measure
pencils
a square
straight edge
reversible hand drill and bits
two levels .... for inside the cavity to level oven
approx a 15 inch .one 6 inch
a hand saw or circular saw
, i found a jigsaw helpful
self tapping screws different lengths
as per the oven fitting requirements
you can use any paint to finish the job
white board or MDF board is ok
some extras strips of timber to level the new oven
maybe required
if imperial was used for the cavity of the old oven
metric might be for the new oven
some DIY about wall oven installs are found on youtube
Oct 14, 2016 | Ovens
Baroness integra plus wall oven oven not heating when fan on
a lot of ovens have 3 elements in them...one up top, one under the base and one in the fan compartment...i would say your element has burnt out in the fan comp.
Jul 24, 2010 | Ovens
Need serial number for my electric coronet integra wall oven
ther should be 4 screws holding the wall oven in you need to take them out and puul the oven out just alittle and look on the sides,be carefull not to far out
Sep 01, 2009 | Ovens
Chef Coronet Integra oven - no manual
Problem not solved, so I will just have to bumble on! Cannot afford the premium plan, but thanks - I have you on my list should something else happen! Thanks Gabrielle.
Mar 20, 2009 | Ovens
Install a baroness integra wall oven
Aug 04, 2008 | Ovens
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Grilling Logo
326 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
