Question about Goodman Heating & Cooling
Hvac i have a 2 ton goodman package unit. the ac side works great the heat side not so good.man lol. it cycles on the gas is ignited and runs for 5 to 10 seconds and flame goes out. it will do this three or for times and then the blower shuts off. if i take out the quick disconnect and put it back in it does the same thing over again. i replaced the flame rollout switch now it lasts a little longer 10 to 15 seconds but still ending with the same results... please help
  • 182 Answers
Dirty flame sensor
Posted on Oct 28, 2008
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
Heating element will not work
CHECK UP THERMOSTATE GIVING CONT. TO hTR. OR THREE WAY VALVE
Nov 11, 2013 | Goodman Manufacturing Goodman GPC1448H41...
I installed my new unit this summer and the ac worked fine, now the heater does not work
frist check that the thermostat and the mood is in right positions then check that thermostat give signal to Htr.if Htr is right ohms
Nov 11, 2013 | Goodman Manufacturing Goodman...
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
I would like to know the specifications of my Goodman model CPKE42-18 AC/Heat pump system. BTUs heating and cooling? Thank You,
Many HVAC people talk in tonnage. One ton is equal to 12,000 Btus. Therefore your model specifies your cooling tonnage at 3 and 1\2 tons. Your heating would be determined by how many if any supllimentary heat strips are added. If you live in Anahiem or Miami that's not really important. But if you live anywhere that gets down into the 40's at night you'll want strips. Cooling wise depending on where you live and what your insulation is like, I'd say your unit is good for 1100-1300 Sq feet of living space.
Jul 15, 2009 | Goodman Heating & Cooling
Keepe shutting down the heat.
Mark is right 5 tons is way too big and you are probably icing up. Even here in Az we size units to no less than 500 sq. ft. per ton and more like 700 sq. ft. per ton. What is the make and model number of your unit? I'm a Goodman Authorized Contractor so I should have most info on hand.
Feb 13, 2009 | Goodman Heating & Cooling
Gas Package Unit Keeps Running with all T- stat wires unpluged at the unit?
does that unit run heating or just the fan run? if just the fan you may have a bad fan thermostat
Oct 21, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
117 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
