Question about Nintendo Wii Remote Controller
How do i program my wii remote - Nintendo Wii Remote Controller
Wii remote will not point and select a program. Remote has been synchronized, seems to be working properly, Board is working and the programs come up on the screen but will not point or let me select a...
Hi. Try to borrow a friend's wiimote that will help you to figure out if it is a sensor bar problem, if it is not a problem with the sensor bar, then it can be the wii software try resetting the console or updating it.
Aug 30, 2011 | Nintendo Wii Fit for Wii
Tip
How Control Your PC with a Wii Remote –
While some of us who jumped on the Wii bandwagon have a great time with Super Mario Galaxy and Cooking Mama, there are undoubtedly a few regretful gamers who just can’t get the hang of Nintendo's waggle-based gaming console. But there’s no need to chuck that Wii out the windows yet---you can use the Wii Remote as a wireless pointer for your PC!
   Find a compatible Bluetooth Adapter -
The Wii Remote uses Bluetooth to connect to the Wii, but Windows will also recognize it as a human Interlace Device. To connect the Wii Remote your PC, you’ll need a compatible Bluetooth receiver. Most new laptops have integrated Bluetooth, but you can also purchase a USB Bluetooth receiver online for less than $25.
Pair the Wii Remote with your PC -
I paired the Wii Remote with our Dell laptop using the "Add Bluetooth Device" option in the Windows control Panel. For the laptop to recognize the controller, I also had to press the red sync button in the Wii Remote’s battery compartment. Your PC should detect it as Nintendo RVL-CNT-01. No Bluetooth passkey should be required.
Run WiinRemote software –
Now, download and launch the latest version of WiinRemote  (Download  it from http://onakasuita.org/wii/index-e.html). If you successfully paired your Wii Remote, the program will let you calibrate the motion sensor and assign buttons. By default, The program user site controller's gyroscope to control your mouse cursor. The Wii Nunchuck peripheral’s analog stick will also control mouse movement. Yon can achieve more accurate control by activating their sensor, bus you’ll need to mount two infrared light sources above your monitor for this to work. The Wii's IR light bar is suitable, and I powered it by splicing its proprietary plug into a USB cable.
So sit back and enjoy the comfort of using a PC with a remote......
on Dec 09, 2009 | Computers & Internet
I have tried programming my wii remote but it won't work. I pressed both the sync buttons, but all it does is flash on all 4 dots and then quits. I've changed the batteries in both remotes, as...
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
Jul 19, 2011 | Nintendo Wii Remote Controller
How do you program the wii remote for 2 players
take the battery cover off the wii controller and press the red button. then open the cover at the front of the wii and press the red button. do this when you are at the wii menu. this registeres the remote
May 29, 2010 | Nintendo Deca Sports for Wii
Lost communications to WII remotes and board
hi, my wii console works exept the little hand from the wii will not go on the screen, the remotes are programmed in and work fine so wondering what the problem could be? if its the sensor bar or something else and can it easily be fixed? thanks
Apr 20, 2010 | Nintendo Wii Console
Setting up my Wii system using Harmony 670 Remote
I just thought you should know the Harmony Remote is only able to control any device that uses infrared control. Unfortunately the Wii console uses Bluetooth technology which means the Harmony Remote would not be able to control it.
Hope this helps you!
-Kennedy
Feb 23, 2010 | Logitech Harmony 670 LCD Remote Control
I have a logitech remote for my tv, just bought a wii game. Do i need to program it into my remote as i cannot get the wii to work?
Because the Wii does not have IR receivers, it is not directly compatible with the Harmony remotes. However, you can still create a "Play Wii" activity that will turn on your other devices that are needed for the activity and set them to the correct inputs. So, for example, you would still need to turn the Wii on manually, but you the "Play Wii" activity would turn the TV on, set the correct input for the Wii and activate your sound system (if separate from the TV). Hope this helps!
Feb 17, 2010 | Logitech Harmony 880 LCD Remote Control
2nd Wii remote not working
sounds like you have a defective wii-mote to me...time to find out how that warranty / exchange program is
Feb 15, 2009 | Nintendo Wii Console
Wii remote
Wii Remote problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
May 18, 2008 | Nintendo Wii Console
Need help programming wii console remote
take off the battery compartment for the Wii Remote, and you should see a small red sync button. While the Wii is on, open up the flap for the SD cards, and you should see a red sync button on the Nintendo Wii. While holding the red sync button for the Wii Remote, press and hold the red sync button on the Nintendo Wii. After a few seconds, put the battery cover back on, and test the Wii Remote. Have any questions, feel free to ask. Use the add more details part in your question to ask any more questions. Thank you and have a good day.
Dec 19, 2007 | Nintendo Wii Console
Nintendo Wii Remote Controller Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
