Question about Ford Garden
REPLACE IGNITION SWITCH 1510 FORD TRACTOR - Ford Garden
Do you have a wiring schematic for the starting system on a 1994 Ford 4630 Diesel Tractor?
Randy, Check the attached link and scroll through it, hope it has the info. you need.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1994 Ford 4630 Diesel Tractor wiring schematic for the starting system...
Apr 22, 2016 | Ford Cars & Trucks
Ford Tractor 5610S Key Switch Diagram
The parts diagrams for Ford tractors are available from the New Holland Parts Store: http://partstore.agriculture.newholland.com/us/ . I see a pair of 5610S tractors listed when I search for that model number. You can use the year of manufacture or location of sale to make sure that you are looking at the correct parts diagram. You want the Electrical Systems diagrams for the electrical switches and battery cables, for tractors sold starting 12/93. Part 6 is the ignition switch; part 8 is the key.
The wiring diagrams are also in the electrical systems section. I hope this helps. If you are looking for something other than the ignition system switch, please add a comment to clarify the parts for which you need diagrams.
Jul 13, 2015 | Ford Garden
I've got a ford 1910 tractor with aerated
that would be a good guess
also low oil in the reservor
Dec 01, 2017 | Cars & Trucks
What is the point gap ford 8n
.015 for 2N, 8N & 9N
The 8N also had problems with ignition switch causing several troubles, cheap and easy to replace....Below link is an excellent site.
http://www.yesterdaystractors.com/atrp/specs/ford.htm
May 14, 2014 | Ford 8N Tractor
Lost my tractor key ford 1910
Hi skybird564
You can try at the Ford tractor dealer to see if they have a generic key for your ignition..if not then replace the switch with a new starter switch you can purchase at any auto parts store.
Please take time to rate me
Bud
Mar 22, 2013 | Garden
Can not start 1985 ford diesel tractor. Turn key on an nothing happens.Need wiring diagram. Help
Check your battery, then if still not starting check ignition and/or ignition safety switches.
Apr 19, 2011 | Ford Garden
Replacing key switch on 85 ford tractor 4600
Hi..my name is Keith..i restore old ford tractors..but i dont have a wiring diagram for a 1985...but usually the connectors on an ignition switch(im assuming that what you are refering to) is labled with an I for ignition..a B for battery..a G for ground and an L for lights..and you can trace the wires to these these componets...i hope this has helped..if not please write me back
Apr 09, 2009 | Ford Garden
Garden Logo
89 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
