Question about Jabra T5330 Wireless Headset
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
I do not hear any sound from the jabra head set when I enable my headset button on my cisco ip phone 7941G.
  • murtadi99 Jan 13, 2009
    I have the same problem, I have all the connections, but I can´t pair the headset with the base.
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Posted on Jan 28, 2009
How do you pair a plantronics (cs351n/a) headset with a cisco IP 7900 series phon (cp-7941g)
Go into your sound settings, and enable the +20 gain settings on your mic setting.
It's a weird thing, mics not detecting what they're supposed to do, but it happens.
Unless you haven't installed the updated drivers for the unit? Try going to the website, and d/load the updated software for it, make sure it's for your hardware, and install it. Winblows can be outdated sometimes.
Hope that helped, in one way or another.
Cheers from New Zealand
Pete
MegaByteMe :)
Feb 10, 2016 | Plantronics Supraplus Cs351n/A Wireless...
I need to modify the settings of my cisco ip phone 7941
Complete these steps:
  1. Unplug the power cable from the phone, and then plug in the cable again.
  2. Immediately press and hold # and while the Headset, Mute, and Speaker buttons begin to flash in sequence, release #. ...
  3. Press 123456789*0# within 60 seconds after the Headset, Mute, and Speaker buttons begin to flash.
Aug 04, 2015 | Cisco 7941G-GE IP Phone
Jabra headset phone
either the switch is partially shorted or the pin on your headet has a shorted wire in it somewhere..try a new headset first..
Jan 08, 2014 | Cisco Computers & Internet
I cant test my 7941g because i keep getting a small bullseye on the bottom left corner of the screen
Your phone is trying to connect to a TFTP server address to download a firmware and/or config file update. You need to figure out what IP address it is trying to connect to (You may have to use wireshark or another packet sniffer to determine this).
Once you know the IP it is trying to connect to, you'll need to set up a small network with a TFTP server running on that same address, and feed the phone a firmware update and/or config file. It will likely not fully boot unless it gets a firmware update.
Cisco Phone 48V Power Supply
Dec 05, 2012 | Cisco 7941G IP Phone
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Good luck from Headsets Direct!
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Can I hook a 1131ag LWAP directly to a 7941g?
If the 7941g is the cisco cp-7941g ip phone then no you can not since the ip phone only has ethernet connections and the airap1131agak has only wireless connections on it as it is a wireless access point, so you will need a wireless router or something similar to get the wireless to ethernet cable.
Oct 29, 2009 | Cisco Aironet 1131AG (AIRAP1131AGAK)...
CISCO 7941 IP PHONE disconnect you out after certain time
Unfortunately this is a very common problem with Cisco's IP Phones. It can be caused by either a faulty hookswitch or a damaged jack. Both of these problems can be remedied by contacting IdacomUSA.
Apr 06, 2009 | Cisco 7941G-GE IP Phone
CP 7941G issue
Try configuring CCM IP address either trough DHCP parameter, or Network configuration on the phone.
Oct 08, 2008 | Cisco 7941G-GE IP Phone
Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Jul 12, 2007 | Cisco 7941G-GE IP Phone
Jabra T5330 Wireless Headset Logo
1,439 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
