Question about Sta Rite Pool & Spa
No power to pump, power disconnected - Sta Rite Pool & Spa
  • randybricker
    randybricker Feb 25, 2012
    ***THE GROUND IS DISCONNECTED
  • Sta Rite Master
  • 1,343 Answers
A cheap volt meter is your best friend when it comes to power issues .. local auto parts store has them and ask how to use it.
Jay the pool pump repair guy in longwood Florida 32750
Posted on Jun 06, 2013
How to remove power steering pump on a 2007 subaru b9 tribeca
before start job suction out power steering fluid out of pump using large sirenge or siphon pump then.you need a table vise and two pieces of wood.okay to remove power steering pump. you need to disconnect the ground cable.remove air intake duct.remove the pulley cover.remove the drive belt.disconnect power steering pump switch connector.disconnect the pressure hose and the suction hose from the power steering pump.cover power steering hose and pipe keep getting trash dirt and debris.remove the installation bolt of the power steering pump bracket.place the oil pump bracket in a vise btween two pieces of wood keep from damaging bracket and remove the two bolts from the front side of the pump.remove bolt from rear side of the oil pump.disassemble the oil pump and the bracket by inserting flat tip screw driver.to install tighten oil pump to bracket bolts 12 ft lbs. tighten the bolt from the rear side of the oil pump to 27 ft lbs.tighten steering hose eye bolts to 30 ft lbs.replace fluid bleed air out power steering system.
Nov 28, 2012 | 2007 Subaru B9 Tribeca
I need to find out how to remove the power steering pump on a 2006 pontiac grand prix 3.8L
Power Steering Pump Replacement
Removal Procedure
1. Remove the accessory drive belt.
2. Raise and support the vehicle. Refer to Vehicle Lifting.
3. Remove the tire and wheel assembly.
4. Disconnect the power steering pressure hose from the power steering pump.
5. Disconnect the power steering return hose from the power steering pump.
6. Disconnect the harness connector (4) from the power steering pump (1).
7. Remove the power steering mounting bolts from the power steering pump.
8. Remove the power steering pump from the engine.
9. Remove the power steering pump pulley from the power steering pump.
10. Remove the power steering pump reservoir from the power steering pump.
Installation Procedure
1. Install the power steering pump reservoir to the power steering pump.
2. Install the power steering pump pulley to the power steering pump.
3. Position the power steering pump to the engine.
Notice: Refer to Fastener Notice in Service Precautions.
4. Install the power steering pump mounting bolts.
Tighten the bolts to 25 Nm (18 ft. lbs.).
5. Connect the power steering pressure hose to the power steering pump.
6. Connect the power steering return hose to the power steering pump.
7. Install the harness connector (1) to the power steering pump (4).
8. Install the accessory drive belt.
9. Fill the power steering system with fluid.
10. Bleed the power steering system.
11. Operate the power steering system and inspect for power steering system leaks.
*This originally came from abauto
Mar 24, 2011 | 2006 Pontiac Grand Prix
Replacement steps for power steering pump - orginal one leaking thanks
REMOVAL & INSTALLATION 2.4L Engine Fig. 1: Location of the power steering pump - 2.4L engine 87958079.gif
  1. Disconnect the negative battery cable.
  2. Disconnect and cap the power steering fluid lines from the pump.
  3. Remove the mounting bolts, then remove the power steering pump. To install:
  4. Install the power steering pump.
  5. Install the pump mounting bolts and tighten to 22 ft. lbs. (30 Nm).
  6. Uncap and connect the fluid lines to the power steering pump. Tighten the line fittings to 20 ft. lbs. (27 Nm).
  7. Connect the negative battery cable.
  8. Fill the power steering pump with fluid and bleed the air from the system.
  9. Road test the vehicle and verify no leaks.
3.1 Engine Fig. 2: Power steering pump mounting detail - 3.1L engine 86888066.gif
  2. Remove the serpentine drive belt.
  3. Unfasten the power steering pump-to-engine bolts.
  4. Pull the pump forward, then disconnect and plug the pressure tubes. NOTE: Place a rag under the pressure tubes to contain any excess power steering fluid.
  5. Remove the engine mount, and remove the pump. NOTE: To remove the engine mount, support the engine with a suitable jack by the oil pan. Make sure to use a thin piece of wood on the jack pad to disperse the weight and prevent oil pan damage. To install:
  6. Position the pump and install the engine mount. Tighten the engine support-to-mount bolts to 96 ft. lbs. (130 Nm). Tighten the engine mount-to-body bolts to 49 ft. lbs. (66 Nm) and the nut to 31 ft. lbs. (42 Nm), and remove the jack from the oil pan.
  7. Unplug and connect the pressure tubes.
  8. Install the serpentine drive belt.
  9. Fill the power steering pump reservoir with the proper type and amount of fluid. Bleed the power steering system.
  10. Connect the negative battery cable and check for leaks.
Nov 20, 2010 | 1999 Chevrolet Malibu
How do you remove the power steering pump from a 2001 Chev Blazer with the 4.3 engine?
4.2L Engine
  1. Remove the air cleaner assembly.
  2. Remove the drive belt.
  3. Install a drain pan under the vehicle.
  5. Disconnect the power steering cooler hose from the power steering pump.
  6. Disconnect the wiring harness from the wiring loom on the power steering pump.
  7. Remove the power steering pump mounting bolts.
  8. Remove the power steering pump.
  9. Remove the power steering pump pulley.
  10. Remove the power steering pump pulley using Power Steering Pump Pulley Remover tool no. J 25034-C, or equivalent.
Oct 30, 2010 | 1993 Plymouth Acclaim
I need to know how to take the power steering off a 1997 dodge caravan?
Power Steering Pump-Let me know if you need to take the power steering gear off: Removal & Installation 2.4L Engine To Remove:
  1. Disconnect and isolate the negative battery cable.
    • Remove as much fluid as possible from the power steering fluid reservoir using a siphon pump.
    • Remove the drive belt from the power steering pump.
    • Loosen the nut securing the front power steering pump bracket to the aluminum bracket.
    • Raise and safely support the vehicle.
    • Place a drain pan under the vehicle to catch the power steering fluid.
    • Disconnect the connector from the oxygen sensor at the rear engine mount bracket. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
    • Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
    • Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
    • Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube. Allow the fluid to drain.
    • Remove the accessory drive splash shield.
    • Remove the supply hose coming from the reservoir from the power steering pump. Drain the fluid from the hose.
    • Disconnect the pressure hose from the pump. Drain off excess fluid from the hose.
    • Remove the return hose from the pump. Allow the fluid to drain from the tube.
    • Remove the nut from the rear of the pump to the cast mounting bracket.
    • Loosen the three bolts securing the pump to the front mounting bracket. Then remove the nut and remaining bolt.
    • Remove the power steering pump and the front bracket from the cast bracket on the engine as an assembly through the exhaust tunnel.
    • Remove the three bolts attaching the front bracket to the power steering pump and separate the power steering pump from the front bracket.
To Install:
  1. Install the power steering pump through the exhaust tunnel of the vehicle.
  2. Loosely install the nut on the rear of the pump to hold the pump to the bracket.
  3. Install the front bracket on the pump and install the three bolts loosely.
  4. Install the nut and bolt securing the bracket to the cast bracket.
  5. Tighten the three front bracket-to-pump bolts to 40 ft. lb. (54 Nm).
  6. Connect the pressure hose to the power steering pump. Make sure to inspect the o-ring and replace as needed. Tighten the fitting to 275 in. lb. (31 Nm).
  7. Connect the low pressure return hose to the power steering pump.
  8. Connect the supply hose from the reservoir to the pump. Make sure the hose is not near drive belt.
  9. Install the drive belt and splash shield.
  10. Connect the fluid return hose to the steel tube on the cradle and cover with the heat shield sleeve.
  11. Properly position the protective heat sleeve over the return hose. Secure the heat sleeve with a tie strap to the hose to keep it in place.
  12. Install the exhaust system.
  13. Connect the oxygen sensor wiring connector to the vehicle wiring harness.
  14. Lower the vehicle.
  15. Connect the negative battery cable.
  16. Fill and bleed the power steering system.
  17. Check for leaks.
3.0L Engine To Remove:
  2. Remove as much fluid as possible from the power steering fluid reservoir using a siphon pump.
  3. Remove the drive belt from the power steering pump.
  4. Raise and safely support the vehicle.
  5. Place a drain pan under the vehicle to catch the power steering fluid.
  6. Disconnect the connector from the oxygen sensor at the sensor wiring harness grommet on the floor pan. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
  7. Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
  8. Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
  9. Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube. Allow the fluid to drain.
  10. Remove the accessory drive splash shield.
  11. Remove the supply hose coming from the reservoir from the power steering pump. Drain the fluid from the hose.
  12. Disconnect the pressure hose from the pump. Drain off excess fluid from the hose.
  13. Remove the two bolts securing the pump to the alternator/power steering pump/belt tensioner bracket.
  14. Remove the pump from the bracket and remove it from the vehicle through the exhaust tunnel on the floor pan.
To Install:
  2. Install the pump on the bracket with the two mounting bolts. Tighten the two bolts to 40 ft. lb. (54 Nm).
  3. Install the pump rear support bracket. Tighten the nut and bolts to 40 ft. lb. (54 Nm).
  4. Connect the pressure hose to the power steering pump. Make sure to inspect the o-ring and replace as needed. Tighten the fitting to 275 in. lb. (31 Nm).
  5. Connect the low pressure return hose to the power steering pump.
  6. Connect the supply hose from the reservoir to the pump. Make sure the hose is not near drive belt.
  7. Install the drive belt and splash shield.
  8. Connect the fluid return hose to the steel tube on the cradle and cover with the heat shield sleeve.
  9. Properly position the protective heat sleeve over the return hose. Secure the heat sleeve with a tie strap to the hose to keep it in place.
  10. Install the exhaust system.
  11. Connect the oxygen sensor wiring connector to the vehicle wiring harness.
  12. Lower the vehicle.
  13. Connect the negative battery cable.
  14. Fill and bleed the power steering system.
  15. Check for leaks.
3.3L & 3.8L Engines To Remove:
  3. Raise and safely support the vehicle.
  4. Disconnect the connector from the oxygen sensor at the sensor wiring harness grommet on the floor pan. NOTE: The exhaust system needs to be moved to allow room for power steering pump removal.
  5. Remove the bolts and nuts securing the catalytic converter to the exhaust manifold.
  6. Disconnect the exhaust system hangers from the brackets. Move the exhaust system rearward and left as far as possible.
  7. Place a drain pan under the vehicle to catch the power steering fluid.
  8. Raise the heat sleeve to expose the clamp and then disconnect the fluid return hose from the steel tube on the cradle. Allow the fluid to drain into the pan.
  9. Remove the accessory drive splash shield.
  10. Remove the drive belt from the power steering pump.
  13. Disconnect the return hose from the pump. Drain the fluid into the drain pan.
  14. Remove the power steering pump rear support bracket.
  15. Remove the three bolts securing the pump to the alternator/power steering pump/belt tensioner bracket.
  16. Remove the pump from the bracket and remove it from the vehicle through the exhaust tunnel on the floor pan.
To Install:
  2. Install the pump on the bracket with the three mounting bolts. Tighten the bolts to 40 ft. lb. (54 Nm).
  3. Install the pump rear support bracket. Tighten the fasteners to 40 ft. lb. (54 Nm).
Oct 13, 2010 | 1997 Dodge Caravan
Where is the power steering dipstick
Most power steering pumps are driven by the serpentine belt and should be in plain view when the hood is open.The following shows how to remove and replace the power steering pump and might give you a clue if not in plain sight. My dad's 1998 Ford Taurus has it nearly on top, but they could have changed things in the mean time: Power Steering Pump Removal & Installation Power Steering Pump (2V) To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the accessory drive belt.
  4. Remove the alternator.
  5. Drain and remove the radiator coolant recovery reservoir.
  6. Position a drain pan under the power steering pump underneath the vehicle. Disconnect the hydraulic pressure and return lines and allow to drain.
  7. Remove the idler pulley from the power steering pump support.
  8. Remove the belt tensioner.
  9. Remove the bracket mounting bolt located under the belt tensioner mounting.
  10. Remove two retaining nuts from the bracket mounting studs. Remove both mounting studs, and pull off the power steering pump support with the pump attached.
  11. Clamp the pump support bracket in a suitable vise.
  12. Remove the power steering pump pulley from the pump shaft using Pump Pulley Remover T69L-10300-B, or equivalent. Remove the three bolts retaining the power steering pump to the power steering pump support and remove the power steering pump.
To Install:
NOTE: The pulley must be installed within 0.010 in (0.25 mm) flush with the power steering pump shaft.
  1. Install the power steering pump to the power steering pump support. Tighten the mounting bolts to 18 ft-lb. (25 Nm).
  2. Install the power steering pump pulley using Steering Pump Pulley Replacer T65P-3A733-C, or equivalent; the pulley face must be flush within 0.010 inch (0.25mm) of the pump shaft.
  3. Install the power steering pump/pump support and torque nuts/bolt to 24 ft. lbs. (33 Nm).
  4. Install the bracket mounting bolt located under the belt tensioner mounting.
  5. Install the belt tensioner.
  6. Install the idler pulley to the power steering pump support.
  7. Connect the hydraulic pressure and return lines.
  8. Install the radiator coolant recovery reservoir.
  9. Install the alternator.
  10. Install the accessory drive belt.
  11. Fill the power steering reservoir with power steering fluid.
  12. Connect the battery ground cable.
  13. Run the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Power Steering Pump (4V) and SHO To Remove:
  4. Drain and remove the radiator coolant recovery reservoir.
  5. Position a drain pan under the power steering pump. Disconnect the power steering pump reservoir hose and allow it to drain.
  6. Using Pulley Remover T69L-10300-B, or equivalent, remove the pulley from the power steering pump shaft.
  7. Disconnect the pressure hose from the power steering pump and allow it to drain.
  8. Remove the power steering pump retaining bolts and the pump.
To Install:
  1. Install the power steering pump and tighten the bolts 15–22 ft. lbs. (20–30 Nm).
  2. Connect the pressure hose and secure the clamp.
  3. Using a Steering Pump Pulley Replacer T65P-3A733-C, or equivalent, install the power steering pump pulley: the pulley face must be flush with the pump shaft or within 0.010 inch (0.25mm).
  4. Connect the power steering pump reservoir hose.
  5. Install the radiator coolant recovery reservoir.
  6. Install the accessory drive belt.
  7. Fill the power steering reservoir with power steering fluid.
  8. Connect the battery ground cable.
  9. Start the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Jul 22, 2010 | 1996 Ford Taurus
How to install a power steering pump for a 1997 chrysler seabring conv
Chrysler Cirrus/Stratus/Sebring/Avenger/Breeze 1995-1998
Power Steering Pump - REMOVAL & INSTALLATION
Cirrus, Stratus, Sebring Convertible and Breeze
(see Figures 1, 2, 3 and 4)
  1. Disconnect the negative battery cable from the left strut tower. The ground cable is equipped with an insulator grommet, which should be placed on the stud to prevent the negative battery cable from accidentally grounding.
  2. Siphon as much power steering fluid out of the reservoir as possible.
  4. Remove the right front tire and wheel assembly.
  5. Remove the splash shield from the right front wheel well.
Fig. 1: Power steering pressure hose attachment to the pump-with Variable-Assist steering
Fig. 2: Power steering pressure hose attachment to the pump-without Variable-Assist steering
  1. Disconnect the power steering pressure hose from the pump.
  2. Remove the hose connection on the power steering pump.
Fig. 3: Typical power steering pump front bracket attachment
  1. Remove the power steering adjusting bolt.
  2. Remove the power steering pump rear attaching bolt.
  3. If so equipped, remove the Anti-lock Brake System (ABS) hydraulic control unit heat shield.
  4. Remove the wheel speed sensor retainer bracket from the right inner fender.
  5. Remove the wheel speed sensor sealing grommet from the right inner fender.
  6. Disconnect the speed sensor wiring.
  7. Push the wiring through the hole in the inner fender.
If not equipped with anti-lock brakes, the hole will just have a sealing plug.
  1. Remove the bolt attaching the power steering front bracket to the mounting bracket. Access to the bolt is gained through the hole for the speed sensor wiring.
  2. Remove the power steering pump drive belt.
  3. Remove the power steering pump and the front bracket as an assembly.
To install:
  1. Install the power steering pump and bracket.
  2. Reinstall the bolt at the adjusting slot, but do not tighten.
  3. Reinstall the bolt mounting the power steering pump to the rear mounting bracket, but do not tighten.
  4. Reinstall the power steering pump top bolt, but do not tighten.
  5. Reconnect the power steering hoses.
Fig. 4: Install a new O-ring gasket on the hose fitting
Use a new O-ring when reinstalling the power steering pressure hose.
  1. Reinstall the drive belt.
  2. Adjust the drive belt and tighten the power steering pump bolts to 40 ft. lbs. (54 Nm).
  3. Reinstall the splash shield.
  4. Reinstall the tire and wheel assembly.
  5. Lower the vehicle.
  6. Reconnect the negative battery cable.
  7. Refill the reservoir and bleed the power steering system.
Sebring Coupe and Avenger
  2. Remove (drain, suction pump, etc.) as much power steering fluid as possible.
  3. Disconnect the return fluid line. Remove the reservoir cap and allow the return line to drain the fluid from the reservoir. If the fluid is contaminated, disconnect the ignition high tension cable and crank the engine several times to drain the fluid from the gearbox.
Cover any components located underneath the power steering pump with a shop towel to protect them from damage due to power steering fluid spillage. For example, the A/C compressor or alternator, depending on vehicle and engine, is below the power steering pump, so cover the A/C compressor or alternator with a shop towel before removing any hoses.
  1. Loosen (but do not remove) the power steering pump mounting bolts and remove the drive belt.
  2. Remove the pressure switch connector from the side of the pump.
  3. Disconnect the pressure line.
  4. Unbolt and remove the pump from the mounting bracket.
To install:
  1. Clean all parts well. Inspect the pump pulley for cracks. Check the hoses carefully for cracks or signs of weakness.
  2. Install the pump, wrap the belt around the pulley and lightly tighten the mounting bolts.
  3. Replace the O-rings and connect the pressure line. Connect the pressure line so the notch in the fitting aligns and contacts the pump's guide bracket. Tighten the fitting to 13 ft. lbs. (18 Nm).
  4. Connect the return line and secure with the clamp.
  5. Fasten the pressure switch connector.
  6. Adjust the power steering belt for proper tension and tighten the adjusting bolts.
Use only MOPAR ATF PLUS automatic transmission fluid type 7176, ATF+3 automatic transmission fluid, or equivalent, in the power steering system of Sebring coupe and Avenger models.
  1. Refill the reservoir and bleed the power steering system.
Hope this help to solve it (remember comment and rated this). TY for using Fixya.
May 13, 2010 | 1997 Chrysler Sebring
How to replace power steering pump
2004 Pontiac Grand Prix V6-3.8L VIN 2
Power Steering Pump: Service and Repair
NOTE: The content of this article / image reflects the changes called out by TSB: 05-02-32-004.
Removal Procedure
Sep 07, 2009 | 2004 Pontiac Grand Prix
Removal and installation of the water pump
3.0L or 3.8L engine?
please rate as fixed if this solves your issue.
Section 03-01B: Engine, 3.8L 1996 Windstar Workshop Manual
IN-VEHICLE SERVICE Water Pump SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fuel Line Disconnect Tool Set T90T-9550-S
Removal
  1. Drain engine cooling system. Refer to Section 03-03 .
  1. Loosen drive belt tensioner (6B209) and remove drive belt (8620). Refer to Section 03-05 .
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Disconnect lower radiator hose (8286) from radiator lower hose tube (8291) and radiator (8005).
  1. Disconnect radiator lower hose tube from water pump (8501).
  1. Remove lower nut on both front engine support insulators (6038).
  1. Lower vehicle.
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove generator (GEN) (10346) from power steering pump support (3C511).
  1. Position drain pan and disconnect power steering pressure line from power steering pump (3A674) using Fuel Line Disconnect Tool Set T90T-9550-S.
  1. Remove power steering reservoir filler cap.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: If using a prying device to assist in water pump removal, be careful not to damage the mating surfaces.
    Disconnect water bypass hose (8597) and oil cooler hose (6B850) from heater water outlet tube (18663).
  1. Remove retaining bolts and disconnect heater water outlet tube from water pump.
  1. Remove A/C bracket brace.
  1. Attach engine lifting eye to left-hand (front) exhaust manifold (9430).
  1. Attach lifting equipment to engine lifting eye and raise front of engine approximately 51 mm (2.0 inches) to provide necessary clearance for water pump removal.
  1. Remove water pump pulley retaining bolts and water pump pulley (8509).
  1. Remove drive belt tensioner pulley retaining bolt and drive belt tensioner pulley (6B217) from power steering pump support.
  1. Remove power steering pump support retaining bolts and nut. Place power steering pump and support assembly aside in a position to prevent fluid leakage.
  1. Remove water pump retaining bolts and nuts and water pump. Discard used water pump housing gasket (8507).
Installation
  1. NOTE: Lightly oil all bolt and stud bolt threads before installation except those specifying special sealant.
    Clean gasket surfaces on water pump and engine front cover (6019).
  1. NOTE: The threads of the No. 1 engine front cover retaining stud must be coated with Pipe Sealant with Teflon® D8AZ-19554-A or equivalent meeting Ford specification WSK-M2G350-A2 before installing.
    NOTE: Gasket and Trim Adhesive D7AZ-19B508-B or equivalent meeting Ford specification ESE-M2G52-A is recommended to hold the water pump housing gasket in position.
    Position a new water pump housing gasket on water pump housing sealing surface.
  1. Position water pump on the engine front cover. Install retaining bolts.
  1. Position power steering pump support and install retaining nuts and bolts. Tighten bolts and nuts to 40-55 Nm (30-40 lb-ft).
  1. Install drive belt tensioner pulley and retaining bolt. Tighten bolt to 70-95 Nm (52-70 lb-ft).
  1. Install A/C bracket brace.
  1. Position water pump pulley on water pump hub and install retaining bolts. Tighten bolts to 8.0-11.5 Nm (71-101 lb-in).
  1. Lower engine and disconnect lifting equipment from lifting eye.
  1. Remove lifting eye from exhaust manifold.
  1. Connect heater water outlet tube to water pump and install retaining bolts. Tighten bolts to 8-11.5 Nm (71-101 lb-in).
  1. Connect water bypass hose and oil cooler hose to heater water outlet tube. Tighten clamps securely.
  1. Connect power steering pressure line to power steering pump fitting.
  1. Install power steering reservoir filler cap.
  1. Install generator to power steering pump support. Refer to Section 14-02 .
  1. Connect battery ground cable. Refer to Section 14-01 .
  1. Install lower nut on front engine support insulators and tighten retaining nut to 88-119 Nm (65-87 lb-ft). Install lower nut of rear engine support insulator and tighten to 77-104 Nm (56-76 lb-ft).
  1. Connect radiator lower hose tube to water pump. Install retaining bolt and tighten securely.
  1. Connect lower radiator hose to radiator lower hose tube and radiator. Position hose clamps securely. Refer to Section 03-03 .
  1. Lower vehicle.
  1. Position drive belt over drive belt tensioner and release drive belt tensioner. Refer to Section 03-05 .
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: This engine has aluminum cylinder heads (6049) and requires a special corrosion inhibiting coolant to avoid cooling system damage. Refer to Section 03-03 for the coolant specifications.
    Fill and bleed cooling system with specified coolant.
  1. Fill power steering pump reservoir with specified fluid.
  1. Start engine and check for coolant and power steering fluid leaks. Service as necessary.
    Water Pump
Apr 13, 2009 | 1996 Ford Windstar
How to replace Power Steering Pump 95 Town Car
  1. Disconnect power steering pump return line and allow power steering pump fluid to drain into a suitable container.
  2. Disconnect power steering pump pressure hose from pump fitting.
  3. Disconnect drive belt from power steering pump pulley, remove pulley, then remove pump.
  4. Reverse procedure to install. Torque pump to mounting bracket bolts to 30-45 ft lb.
Jan 23, 2009 | 1995 Lincoln Town Car
Pool & Spa Logo
32 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
