Question about HP 4250 Monochrome LaserJet Printer
13.20.00 paper jam error
I have a new hp4250 printer that I have just set up and I am trying to test out. Each time it starts to go, I get a 13.20.00 error on tray2. It never tries to feed the paper thru. The 2nd tray goes up but before the paper starts to go thru I get this error.
  • sawiris Nov 10, 2008
    Upon turning on the printer it goes through its pre-start routine. It displays memory, as it cycles through the three LEDs and then it displays the clearing paper path message. Once it completes clearing the paper path, the LED's go out and then it comes back with the error:
    13.20.00 (HP LaserJet 4250n). I swapped out tray 2 and am still getting the same error message. What is ironic is, tray two works in anothr printer without issue.
  • 66 Answers
i think you having problem on your pickup rollers maybe it's worn out that's why you having that message always...try to replace the 2pcs, pickup roller to fix your problem..
i hope it would help you...
Posted on Oct 29, 2008
2 Suggested Answers
SOURCE: 13.20 error on tray 2 of HP4250
Paper in the back of printer where the duplexer is. Could also be the fuser is going bad.
Posted on Jul 23, 2009
I have an HP laserjet 1010. i got the paper jam
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
May 30, 2010 | HP LaserJet 1010 Printer
Jul 23, 2009 | HP 4250 Monochrome LaserJet Printer
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
HP G85 PAPER JAM ERROR ,but still prints from scanner fine
Remove the rear cover...clean the rubber rollers with alcohol
Feb 17, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
HP4250 printer - 25-30 pages stuck
Sorted it myself in the end.
Unscrewed the hinged plate covering the transfer charge roller(?) to release pressure on from the 25 sheets of paper.
Then pulled the paper back through.
Re-assembled and tested OK
Jun 25, 2008 | HP LaserJet 4250n Printer
HP 4250 Monochrome LaserJet Printer Logo
3,237 people viewed this question
Seeker5211
Seeker5211
