Question about Vehicle Parts & Accessories
My Viper 7652V alarm isnt working. The blue light keeps blinking. Even when I'm driving. The remote wont lock, unlock, or start the car anymore. Can someone please HELP ME???
  • 87 Answers
SOURCE: my viper alarm remote just beeps flashes TX and
Try to reprogram this. If this routine does not work please let me know and we will try something else
Posted on Jun 03, 2009
insanegtp
  • 112 Answers
SOURCE: I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
Posted on Jan 29, 2009
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
SOURCE: crimestopper keyless entry remote wont unlock or lock anymore changed battery still wont work
need to program a new remote to keyless entry system it is crimestoppper cs835 rke
Posted on Dec 16, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I think I messed up the remote programing.. When I press to lock the doors they do lock but the horn doesn't honk anymore.. The blue light on the dash does not light up either.. I can still remote...
If the led is solid blue when the key is out of the ignition that means your in valet mode. Which would disable the alarm, but not the starter.
Simply turn key to IGN position then back to OFF.Push the valet button which is on the antenna next to the led and the led should turn off.Close door on vehicle and lock vehicle.Siren should now chirp.
Cheers!!
Sep 16, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper remote worked perfect, until now. the unlock/lock and function button work perfectly, except now the car wont start. the start button works and the car tries to start but shuts down. all the...
The issue is not with the remote as you have stated the vehicle attempts to start. The issue may be with an immobilizer bypass module but, I can't say for sure because you mention the year/make/model of the vehicle. Usually the vehicle will give you visual reason for the failed attempt( the lights will flash a set number of times). But, in any event, the issue is not with the remote and more information is required to assist you.
Apr 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a Viper 5301. Just recently the blue light on the valet stopped blinking when the car is locked with the remote. It just stays on all of the time, no blink. At the same time, the remote started...
The blue light on solid means that your alarm is in the valet mode. Open any door, press lock, unlock, lock. This should put the alarm back into an active mode. Afterwards, check the system for normal operation.
Apr 14, 2011 | 5301 LE 2 Way Car Remote Starter System
My remote will say that its locked but my car alarm wont sound to say its locked, OR ALARM when i lock the door would be open....also the blue LED light that normally blinks when the systems are alright is...
Your alarm is in valet.Open the driver's door, press lock, unlock, lock. The blue light should go out and the chirps should sound when locking and unlocking now.
Feb 27, 2011 | Remote Start System
Just notice blue lights flashing in the car. I unlocked, from inside the house, and manually locked from the lock on the inside door. That stopped the flashing blue lights. What has caused...
Do not be alarmed; the blue light is flashing because you used the remote to lock/arm the vehicle. It is a visual theft deterrent, even if you do not have an alarm. It's normal. The reason the light stopped flashing is because you unlock the vehicle with the remote and locked it with the door switch.
Feb 11, 2011 | 5301 LE 2 Way Car Remote Starter System
The alarm doesn't chirp and no flash of my headlights anymore. Also the blue light stays on the little receiver/antenna on the windshield wheather it is locked or not. What is the problem?
sounds like the alarm went into valet mode. that's usually what a solid blue light means on most viper alarms. check your owners manual on how to take the alarm out of valet mode. with the 5701 alarm its usually done with the remote. hope this helps
Aug 04, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Wont unlock or lock on my 06 tacoma
If you have replaced the battery in the remote, go to the fuse box and check the fuses.
Jul 29, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote starter does not work but will unlock and lock doors.
depending on your alarm which it sounds like a viper model maybe? on my 02 you have to incorporate a factory alarm bypass module in order to be able to start the truck, they run about 100.00 bucks and have to be profssionally installed. The truck wont start because the computer isnt recieving the proper starting sequence due to the factory alarm
Jan 11, 2009 | 2003 GMC Sierra 1500
Vehicle Parts & Accessories Logo
127 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
