My westinghouse mastermind 708 front loader washer is flashing
Flashing ie on the screen what does this mean as it is not allowing water to fill.
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
SOURCE: I have a mastermind 708
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Posted on Nov 22, 2008
SOURCE: My westinghouse mastermind 708 is
most home appliances have many ELECTRONIC components......these components are very sensitive to electrical irregularities that enter your home electrical system......these irregularities can cause some components to freeze up.......pull the plug and leave your westinghouse 708 unplugged for several minutes.......plug it in again and it will reset all of these control components........hope that helps!
Posted on Jan 07, 2011
  • 6277 Answers
SOURCE: why does my westinghouse 708
Sorry but I do not know your particular machine BUT it could stand for 'filter error'.
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 26, 2011
KevinWhite
  • 1902 Answers
SOURCE: I have a Westinghouse Mastermind 711 Front Loader
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Posted on May 27, 2011
Testimonial: "Thanks a lot. I have tried and it worked. Your site is awesome. Thanks"
What does flashing nf sign means on the samsung front loader
It means "No Fill". NOt enough water is making it into the washer. Make sure your water connections are good and hoses are not kinked.
Jul 24, 2016 | Samsung Energy Star 3.9 Cu. Ft. Front Load...
I have a Westinghouse front loader 708 it starts to fill not much water goes in then it try's to wash and comes up with a Ce error
Consult the owner's manual--usually the Troubleshooting section. Or search internet for the Make + Model + the word "Ce"
Mar 05, 2016 | Westinghouse Washing Machines
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Kevin
May 27, 2011 | Westinghouse Washing Machines
My westinghouse mastermind 708 is flashing SE or 5E? what does this mean please?
Jan 07, 2011 | Westinghouse Washing Machines
Westinghouse mastermind 700 flashing HE
I just had to lighten the load. I think that HE means heavy. It works fine now.
Aug 24, 2009 | Westinghouse Washing Machines
Error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Oct 21, 2008 | Washing Machines
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Aug 03, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
Jun 03, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
