Question about Dell 3130cn Color Laser Printer
I'm getting a faint blue line on my print copies. What does this mean?
When using the color printing properties, my copies come out with a faint blue horizontal line across the paper at 3 or 4 places. This does not seem to occur when I select the black print option. How can I correct this?
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
SOURCE: Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Posted on Apr 30, 2008
Corysf62
  • 188 Answers
SOURCE: Deteriorating image quality
Good Evening Robert,
The setting for non dell toner only controls the fuser temperature, and will not cause you any print quality issues. Toner is actually made up of ink and plastic. The fuser melts the plastic to "fuse" the image to the paper. Dell toner is set to "fuse" at a specific temperature. when you use non Dell toners, the temperature required to fuse may be different, and when set to non dell toner setting, the fuser temperature is raised to the maximum to ensure the other toner fuses properly. The down side to this is that you will wear out the fuser sooner then it should.
As far as the print quality issue you are having, it is most likey caused by the imaging drum.
Regardless of the estimated life for the imaging drum as stated by the printer, this is just an estimate. Many things can and will cause the imaging drum need replacing. ( Just yesterday I replaced a black toner in a 3115 that was less then a month old... genuine Dell... with more then 75% expected usage left because it was defective).
On this printer, each of the 3 colors and the black are all independent of each other with the exception of the imaging drum. Even within the imaging drum, cyan and black are independent of magenta and yellow on the first stage of transfer. When you have deteriorated print quality that effects more then one color, the first step is to replace the imaging drum.
The Primary transfer, secondary transfer, and tertiary transfer of the image are ALL contained within the imaging drum.
The chances of having 3 or 4 bad Developers is very very slim. If your print quality issue was related to only ONE color, then I would say you had a bad developer unit ( the 4 items located behind the imaging drum when removed). These are far more difficult and expensive to change.
The BTR ( bios transfer roller ) is the only other item that "could" effect your print quality, however, based on the symptoms you discribed, I doubt it. Besides, if i am not mistaken, the imaging drum kit comes with a new btr anyway.
Although I am sure you may be disappointed with the fact the drum unit is failing while showing it still has life remaining, the solution to replace it should restore your unit to full operation. The unit is light sensative, and effected by physical age as well as the number of prints it has supplied.
Please evaluate the solution i have provided and, rate the solution appropriately to show your support.
Thanks,
Cory
Posted on Oct 11, 2008
  • 40 Answers
SOURCE: want to print with black ink cartridge only
It is a little known fact that ink cartridges do have an expiry date, and it is sometimes possible that even if a printer reads full, that it has dried out and will not print. When you recieve a warning that your ink is too low you will simply be unable to print black ink after a certain point. Generaly if you want to print in only black you will have to do that when you print a document. For instance in IE when you go to file and then print you can select prefrences and select print in greyscale or black. hope this helps!
Posted on Jan 25, 2009
yooperbud
  • 8637 Answers
SOURCE: Dell Photo 926 printer no longer feeds paper correctly
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
How do I clean the printhead on Sharp 3501N?
Hi, Go into printer properties. Click on clean printer chartridge.
When you do this it will run automatically. Do this several times to make the color come out clean. Good luck.
Apr 01, 2014 | Sharp MX-3501N All-In-One Printer
Faint printing
Have you by any chance set the print properties to DRAFT? that will print a light copy to save ink and looks like what you describe. goto printer properties and select the correct mode or default.
Mar 24, 2014 | Brother MFC-7440N Multifunction Network...
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Ricoh copier running vertical blue lines on colored copies. What's the problem?
there is chance that line appear on drum blade
try one thing just block copy during print
mean inside machine
and check ur drum by pulling outside if there is line on drum (blue) then u have to chnage drum
other wise on tranfer glass there is any dust can also make this problem
Aug 03, 2011 | Ricoh Office Equipment & Supplies
Can't find copy menu to take a copy of an address
May i know the printer/ copier model number to assist you better ?
The general rule is, If your printer is a Color printer, then it should have a button/option for COLOR copy.
If it does not have a button/option for Color that means it prints only in black.
Jun 13, 2011 | HEWLETT-PACKARD Hp Ac Adapter Power...
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
Printing is way to light
if your prints are coming out with blue green tint, more than likely, the magenta (pink) is missing from your calibration page. Print out a calibration sheet, you should have black, yellow, blue, and magenta. If one of these colors is missing, your printhead is clogged. You need a new one. Call Kodak Tech Support.
Oct 03, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
When printing in color on 5150 Lexmark All In One, my color copies get horizontal lines in what ever I am copying.
Sounds like you need to clean the print heads.
Right click on your printer, and choose properties (I believe) and there should be an option in there somewhere that says clean print heads. Let that run and see what happens.
Aug 11, 2008 | Computers & Internet
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
Dell 3130cn Color Laser Printer Logo
412 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
