Question about Emerson Audio Players & Recorders
How do I fix the driver for my Emerson mp3 player?
When I plug in my Emerson mp3 player into the computer, it says that the driver is damaged. My mp3 player does not come up on the computer screen anymore. How do I fix the driver problem?
  • yadayada
    yadayada Feb 25, 2012
    Have you tryed to reinstall the driver?
    Top Expert:
  • Emerson Master
  • 75,424 Answers
Hello
Try these links to download the driver for your MP3 player. After download the driver, install it to computer. Your device will be detected after proper diriver installation.
driver
Posted on Feb 25, 2012
SOURCE: I Need a driver for my emerson Musicstick mp3 player
Not sure this will solve every ones problem but I had to upgrade media player to Version 10 to get this to work. I was running XP SP2 with media player version 9 and could not get it to show up in My computer. Also with ver9 I could download to the device but it would not recognize the files. Once I upgraded to ver10 all was golden. I think you also need to have USB 2.0.
Hope this helps
Posted on Feb 28, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: My computer isn't detecting my Sansa mp3 player anymore.
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
  • 3 Answers
SOURCE: Can't get my mp3 player to charge, or turn on.
look on back or sides their might be a lock button on it and it might be locked soyou cant use it
Posted on Dec 16, 2008
SOURCE: mp3 player says ''no file'' after repeated Sync attempts
I have one of these too and finally figured it out! If you push the menu button on the side, you get a menu that you can scroll through with the left/right arrows on the face. The music icon should be first in the list, but if not, scroll until you get it highlighted. Once highlighted, push menu again to select it. My trouble was in not realizing that the menu button is also the select button!
Posted on Mar 25, 2009
  • 608 Answers
SOURCE: MP3 Player Not Charging!!! (USB)
The most common cause is a flat battery. There is a trick to charging
the battery in these small mp3 players. It wont charge if it is turned
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje player on
3. turn it off by either holding down the play button, or selecting
"System" from the menu
4. The screen will go black and the battery will begin charging.
Posted on Mar 28, 2010
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
How do i delete everything off of my emerson mp3 player?
all you do is hit the reset button on the back of your mp3 player
Jan 26, 2010 | Emerson BAR900 MP3 Player
How do I delet music from my mp3 player (emerson)
You plug your player into your computer and click open files and then right click on the song u want to delete and click delete
Jan 17, 2010 | Emerson MP530 MP3 Player
The driver for my Emerson 2gb MP3 player is on an undersized cd. How do I get the driver?
Emerson does not have a support page on their web-site for driver downloads.
Dont know if this will work, try it:
Update driver on your computer using Control Panel, then System, then Hardware, then Device Manager, then Storage Volumes. When promted to update or find a new driver select to find your own windows driver and select the "USB Storage Device" drivers NOT the MTP Drivers. You should see the Emerson MP3 player icon in My Computer after files are configured.
You can also see if some friends might have a CD/DVD player that accepts the smaller discs, if so, have them copy the entire disc to a USB Flash drive or regular CD. Then try to install it from there.
Dec 01, 2009 | Emerson MP530 MP3 Player
I have emerson mtp ver 3.50.00 it will say music has been added on computer but dsnt show on mp3 its not on voice mode
Ok, it took me several hours to figure out such a simple problem. I couldn't open my Emerson 3.50 up on the computer. Therefore I couldn't delete any of the music or add more. It is because it isn't downloading the right driver. You have to manually search your computer for the USB Mass Storage driver and install that. Go into Control Panel, then hardware/sound, then Device Manager. When in device manager find your portable devicse and click on it. Then click on Audio Player. choose update driver and instead of auto driver select, choose "Let me pick a driver". Then choose USB Mass Storage for the driver. Once it has updated you will see all of your songs on Media player. And it works as an MP3 player should!
Sep 05, 2009 | Emerson Audio Players & Recorders
Emerson mp3 stick
go to some one that has window vista
Dec 26, 2008 | Emerson MP530 MP3 Player
Mp3 player says ''no file'' after repeated Sync attempts
Dec 17, 2008 | Emerson MP530 MP3 Player
Hope this helps
Nov 24, 2008 | Audio Players & Recorders
EMERSON MP3 MUSIC PLAYER, EMP312-1, "FILE SYSTEM" ERROR
ok here we go i dunno how i figured this out lol but it took a while. okay so ur gonna go to control panel, device manager, and uninstall the driver for mp3 player. then disconnect mp3 player and reconnect it to reinstall mp3 player. it will recognize it as emerson mp3. right click on it (im running xp) go to properties, click on the tools tab and click on check now on the error checking and select both options of automatic fix file system errors and scan for and attempt recovery of bad sectors. then hit start and it will start the process of fixing the file error. it takes a couple minutes and when its done disconnect the mp3 player n turn it on and voila!!! it works again. if u need more help u can e-mail me at davidh9732@hotmail.com. hope this helps yall so u dont throw them away
Oct 27, 2008 | Audio Players & Recorders
449 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
