Question about Lucent AT&T 1825 Corded Phone (23069)
Lucent 956 corded phone
The caller ID will not work and the lights won't come on
  • jand142 Nov 03, 2008
    I found electrical the line to the phone was defective. Thanks,
5 Suggested Answers
cnavarro
  • 2460 Answers
SOURCE: Caller ID
There's a whole sequence of CID associations that need to be done to make CID work the way you want it. It requires an 18 or 34 D, and you start turning on system programs 317, 318, 319 and program a Feature 23 button to the phone that logs all calls.
A linkable PDF is available here. Start at section 4-10 and use the blue links to understand the programming. Full step-by-step instructions are beyond the scope of a free forum.
http://support.avaya.com/elmodocs2/partner_acs/r7/456801_6/456803_6/456803_6.pdf
Carl
Posted on Oct 07, 2008
Vit Avaya BP
  • 211 Answers
SOURCE: VIEW PREVIOUS CALLER ID LUCENT 6424D+
Closing. User didnot reply
Posted on Mar 25, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: need to know how to set up the caller ID feature
After your caller id is enabled by carrier, you will get it automatically if your processor is release 3 or higher.
Posted on May 27, 2009
cnavarro
  • 2460 Answers
SOURCE: how do I enable caller ID on a Lucent MLX 10DP
The CID comes from the trunk card and cabinet. It's probably a Legend or a Magix system. If you don't have the proper hardware, you need to order and program it.
Your best bet is to call your AT&T/Avaya/Lucent installer and check with them as it's beyond the scope of a free forum to give exact instructions.
Carl
Posted on Oct 14, 2009
Testimonial: "Thanks, Carl! I thought it would have been easier than this... bummer!!"
consultel1
  • 858 Answers
SOURCE: Lucent Partner 18D - Caller ID not working
The caller id information is sent from your local telco provider after the first ring and might not be able to be extended to the individual sets, try backing off the ring to answer on your voice mail from 2 to 3 rings to see if the information is then passed on. The Voice Messaging System message is being sent from the system showing who transfered the call to you. You should also notice that the ring pattern when that message is displayed is a standard ring followed by a beep meaning a transfer is taking place.
Posted on Nov 21, 2009
Lucent Technologies 7311H14b in good shape but need caller ID
Yes you can get stand alone caller ID units, they simply plug into the main line in phone jack. BTW, If you have a modem in your PC you can also then use it as a telephone "anything" Call center, answer-phone, voice-mail, and of course Caller ID. A lot of the software is freeware available on the 'net for download and install.
Jan 31, 2010 | Lucent PARTNER18 Corded Phone
Nov 20, 2009 | Lucent PARTNER18 Corded Phone
How do i get my lucent partner 18d to show caller id name & number
2 line caller id is offered on newer versions of software. On earlier versions a call id name button is used to toggle between the clid name and number.
To program a button on your set press feature 00, press a button you wish to program as clid name,
and press feature 16, press feature 00 to exit programming. Press the button to toggle from clid number to clid name
Nov 03, 2009 | Lucent PARTNER18 Corded Phone
Lucent Partner 18D telephone turn on caller id
On one of those phones, press "feature 59" That will display the release of the processor. It might be that your processor is not CID capable.
Jun 04, 2009 | Lands Phones
Need to know how to set up the caller ID feature
May 21, 2009 | Lucent PARTNER18 Corded Phone
Lucent Caller ID
It depends on the version of partner ACS/ partner plus you have.If your version is after 4.0 it should do a two line caller ID. 3.0 and before you can program a button to toggle from number to name. thats done by pressing the feature key followed by 00, pressing the button you wish to program as clid name and entering feature 16, press feature 00 when finished.
hope that helps
Mar 17, 2009 | Lucent PARTNER18 Corded Phone
My line one caller ID is not working, but my other lines are.
Partner gets caller id from a carrier. If you have a caller id service it will show on your 18D
Dec 09, 2008 | Lucent PARTNER18 Corded Phone
Caller ID
Carl
Oct 07, 2008 | Lucent PARTNER18 Corded Phone
Viewing caller id
Check out your user's manual, but I think you need to start programming lighted buttons with FEATURE 16 and 17.
Carl
Sep 05, 2008 | Lucent PARTNER18 Corded Phone
Lucent AT&T 1825 Corded Phone (23069) Logo
43 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
tfelton3
pbxinc
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
