Question about Maytag MSD2732GR Side by Side Refrigerator
Mff2558vew bottom freezer is developing a sheet of ice
SOURCE: Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
kel1guy2002
  • 3740 Answers
SOURCE: i have a maytag bottom freezer refrigerator model#mbf1956keq
Hi James and welcome to FixYa. I am Kelly.
The thick sheet of ice can be caused by a clogged evaporator drain. Sometimes for unknown reasons the drain will freeze up.
Here is what you can do to begin with to try and unclog the ice block.
1. unplug the unit.
2. remove freezer contents
3. place a fan blowing into the the freezer section for about 2.5 hours due to having to melt the ice in the blocked drain.
4. be ready to tend to a dripping puddle making mess during the manual defrost.
5. Plug the unit back in and see if it works well after about 4 hours.
Here is a way to test your icemaker IF you think that is the problem AFTER the manual defrost:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
I suspect the real problem is in the automatic defrosting circuit. We can talk about that if the unit freezes up again in about 3 to 4 days. Just respond here.
Thanks for using fixYa
Kelly
Posted on Apr 04, 2010
  • 949 Answers
SOURCE: leaks water overnight,thin sheet of ice on bottom
This is most likely due to a defrost drain issue. See the attached link for information on this and how to clear it up. Let me know if it was helpful.
Water leak
Posted on May 28, 2010
SOURCE: water leaking out of left side of freezer at bottom
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
heatman101
  • 43501 Answers
SOURCE: water accumilates in the bottom of the freezer in
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
I have a maytag bottom freezer refrigerator model# MFF2558VB3 that is forming a sheet of ice on the bottom.
Type in the search engine on your computer Refrigerator Repair-Ice in the freezer- Whirlpool, Maytag, Kenmore
Do that and it should give you your answer.
Jun 19, 2017 | Maytag Refrigerators
My Kenmore Model No 596.69282012 bottom freezer fridge develops a thin sheet of ice on the bottom of the freezer compartment. I have checked the freezer seal and it is intact. Any suggestions?
Is it supposed to be a frost free freezer?
I had one to act like that, but it was on warranty and they repaired it for me.
I wish I could have been able to help.
May 15, 2017 | Kenmore Refrigerators
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Ice in refrigerator
Usually a blocked drain at the rear just above the bottom shelf. Use a plastic drinking straw to clear the hole. Could just be condensation if you are in and out of the fridge a lot.
Aug 07, 2012 | Frigidaire FRT17B3A Top Freezer...
5 years - no problems, then started to ice up . Ice forms in the bottom and will develop 1 to 1 inch thick sheet in about 10 days
Check drain under freezer coils and clean out. Look out for frozen drain instead of trash Use hot water or turn off 24 hrs if that is the case. I usually insert a phillips screwdriver dowm in the drain and
pour hot water on the screwdriver so the heat transfers downm the screwdriver to the ice clog.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Maytag 15.6 cu. ft. Upright Freezer...
I have a Kenmore refrigerator 596.71864101 that develops a thin sheet of ice on the bottom of the freezer (which is on the bottom) even after I shut of the water to the ice maker. It seems to be dripping...
You are right about the source of the water. It is coming from the evaporator coils. When the freezer goes into defrost mode, it melts the ice on the coils. The water is supposed to run out of a drain below the bottom of the floor of the freezer. It is common for these drains to freeze shut. If you clear this drain and remove all of the ice from the pan under the floor of your freezer, your problem should go away.
Feb 05, 2010 | Kenmore Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Sheet of ice forms on bottom of freezer
Your defrost heater assembly has probably failed. Look at the ends of the heater for darkness like that of a bad neon bulb. Replace the heater assembly as a unit after removing the ice with a hair dryer. Becareful not to drop the glass heaters when replacing.
Jan 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag MSD2732GR Side by Side Refrigerator Logo
29 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
