Question about Columbia Telecommunications Group Radio Communications
I have a pair of walkie talkies, rechargable, but one of them wont work with the battery pack. Both battery packs work in the other one, but this one will only work with 5 AAA batteries. Any ideas out
The model number of this radio is GM3W. Thanks for looking everybody.
  • Paul Watz
    Paul Watz Apr 01, 2012
    the other battery works in both radios and charges in both locations.
  • Columbia Tel... Master
  • 1,654 Answers
If your rechargeable battery pack takes a different battery tray than the alkaline, you possibly have a bad connection in the battery tray. If they appear to use the same battery contacts, look at where the rechargeable battery touches compared to the alkaline. There may be a problem in this area. Clean all contacts with a pencil eraser to insure your radio is free of debris on the contacts.
Best regards.
Posted on Feb 28, 2012
Neto
  • 123 Answers
SOURCE: configuring audiovox GMRS1072CH walkie talkie
With the issue of 240V if the charger has not a Voltage switch, you will need to find another charger/transformer with the same Voltage/Amps ouput that works with 240V.
For Vox operations, this feature works independly form channel, you should choose the channel# and code # first, to match both radios, and get them communicate, then the Vox feature.
In Some radios the VOX feature works with an external audio accesory, in other radios works with out it.
Basically if this radios works without it, you should see that the radio transmist by itself when you speak direct to the radio, and stops transmiting 1 or2 seconds after you stop talking.
Good Luck.
Posted on Nov 21, 2007
ZZRuss
  • 26 Answers
SOURCE: low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Posted on Jan 07, 2008
eradiostore
  • 1654 Answers
SOURCE: Columbia Walkie Talkies - Model: GM3W - need batteries
You might try contacting Power Products http://www.powerproducts.com/ They may have something available, or be able to build them for you.
Posted on Aug 27, 2008
eradiostore
  • 1654 Answers
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
You have your interference code eliminator set differently on the two radios. Here is a link to the T5 user guide (sorry I didn't have a link to the T3, but they should be very similar): http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
Posted on Feb 28, 2010
eradiostore
  • 1654 Answers
SOURCE: I am trying to pair my motorola walkie talies
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
You will need to program the frequency, code and Qt filter (if any) to match. For basic operation set the frequency and then set the code and Qt filter (if any) to off (zero).
Best regards.
Posted on Apr 15, 2010
Cobra microtalk will not charge
this is the sign of a damaged or dead battery pack. they can be rebuilt at Batteries Plus or replaced. I would also try alkaline batteries in the radio before spending money on new battery packs. Most rechargeable battery packs must be kept charged regularly, and should be fully discharged before recharging, or they will be damaged and end up with a limited lifespan. IF you are handy with a multimeter you can check to see that the charger is putting voltage out by placing the probes on the contacts while it is plugged in. especially if the cord is twisted or looks stretched, but generally it is the battery not the charger.
Sep 03, 2014 | Cobra CXR875 30 Mile 22 Channel FRS/GMRS...
Low batter warning
Hi Kathy,
Wakie talkies are low powered, cheap toys for kiddies to play with.
Having said that, the problem is that you need to try using rechargeable batteries or lithium batteries.
These radios eat batteries, so the better the battery type, (more expense), the longer they last. I would advise that use be restricted to short periods at a time and to remove the batteries when not in use. Better still pay for a real CB radio and not have these problems.
CB radios can be obtained on ebay (Brand New), from as little as $125.00, the units come with lithium rechargeable battery packs and charger.
Cheers,
Peter
Feb 25, 2013 | Radio Shack Walkie Talkies 21-1864 Purple...
Is it ok to leave our walkie talkies in the dual charger on weekends etc or does it damage the rechargeable battery packs?
The charger should have a built in circuit that will shut off when fully charge, but if it doesn't then the battery will feel supper hot and it is bad to over charge batterys and packs. It cut down on life time.
Apr 10, 2012 | Radio Communications
Cobra pr 3850wx bought new NiMh 800mAh 1.2v rechargable batteries now the base charger lights won't come on when i put the radios in it
  • A Cobra 3850wx Radio requires 4x600mAh NiMH 1.2V AAA Part # GA-3ANH rechargeable batteries.
  • Not just any AAA rechargeable battery will charge in the unit.
  • All will work in the radio but not all will charge inside the radio. It has to be a specific battery.
  • This is an example of what you need. GA-3ANH batteries which will charge inside your radio. http://www.tomsawyer2wayradios.com/catalog/item/3823249/5076887.htm
Regards, Tony
May 22, 2011 | Cobra Microtalk 100 FRS Walkie Talkie...
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Walkie talkie batteries don't last
What you have been using are consumer grade walkie talkies. The rechargeable battery packs in them should last a full business day, unless you are in a high use area. This being said, it is also possible you might need to replace the rechargeable battery pack as they usually have just a one year life expectancy. As they start to fail they will go less and less time in a day.
To answer your question about a radio which will go a full business day, any of the business division Motorola handheld radios would work. Radios such as the CP110, BPR40, CP185, and CP200 are all make to go a full day and sometimes more. Their battery packs depending on chemistry would also need to be replaced every 18-24 months.
Best regards.
May 14, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Put batteries in and walkie talkie does not work
either the batterys are duds or the walkie talkie doesnt work- junk or have repaired :)
WE love to help :) and its FREE! so please be kind and thoughtful in your ratings. THANK YOU!
Mar 30, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
It came with battery i assume are rechargable but when plugged in there is no sign that they are charging and when you take them off the charger they die in a few seconds
It looks like some of these came with alkaline battery backs, some with rechargeables, and some with no batteries. The rechargeable packs will be marked "NiMH" with the part number FA-BD on them. If yours are the rechargeable types they probably need to be replaced. You can also power the units with 4 AAA alkaline batteries.
Bill B
Feb 25, 2010 | Cobra MicroTalk FRS 110-2 (14 Channels)...
Low battery icon on Midland LXT350 walkie-talkies
Jan 01, 2008 | Radio Communications
Radio Communications Logo
119 people viewed this question
Top Columbia Telecommunications Group Radio Communications Experts
eradiostore
eradiostore
Michael
ka4iup
ka4iup
Are you a Columbia Telecommunications Group Radio Communication Expert? Answer questions, earn points and help others
