Question about Pool & Spa
What is the water fault error on a compu pool saltwater system
  • 11 Answers
SOURCE: please give me the start up directions for the
hold arrow down till beep hold arrow up till beep press up arrow to desired amount of hours then hold both arrows down till beep to lock in schedule. It will run that schedule every day.
Posted on Jun 06, 2010
  • 11 Answers
SOURCE: code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
Posted on Jun 15, 2009
SOURCE: Salty taste, high ph levels, algea and have shocked pool twice
I'm just now setting up my Saltwater generator...so don't have your problem - yet! Local pool guy tho said with the saltwater systems you need to add dry acid to the pool almost weekly to keep the ph down. Sounds like what you're experiencing. The dry acid was cheap and came in small-ish containers, should last long time.
HTH.
Posted on Jul 07, 2009
  • 297 Answers
SOURCE: Our pool is getting a greenish looking color...
Filter filter filter
Adding salt is not the answer
First of all you need to check the salt content. Do not listen to pool supply places they just want your money
You need a salt test kit about 10 dollars for 10 tests
(get your ppm to as close to 3000 as you can. over this amount and the water tastes like the ocean and under, you are getting to close to 2500ppm at which time your chlorine generator will not produce at the 3000 it gives you room to the 2500 for adding water from splash out or rain)
you can do this while dealing with the algea if you are to high drain 20% water and add fresh keep doing this until you get to the 3000
at the same time you need to buy the right amount of shock treatment for gallons of water in your pool. You can even over add if you want. This is basically extra chlorine.
The trick to this is very time consuming what you need to do after adding the shock is to vaccum/brush/and filter for a few days while making sure to clean your filter cartridge a few times a day
now on to why this happened
Intex sucks :-)
I do not know what size your filter is but chances are good it is not sufficient
A good rule of thumb is that you need to turn the pool water over at least 3 times a day so just for #'s Sake lets say you have a 4000gallon pool and a 2000gph pump your filter would need to run for 2 hours to turn it over once 6 hours for 3 times you will need to do the math with what set up you have
a big cause of algea is lack of use/not enough adjutation heat sun rain and low chlorine
also never let anyone in the pool that is dirty or that has sun products on
now asuming you get everything under control make sure again that you are close to 3000ppm for salt
1.5 -3.0 for chlorine
and 7.6 or so for ph
do not worry about alkalinity
the intex set up is like an inexpensive toy so they are not built well nor do they last but for the money I guess you cant complain too much
here is what I have learned and what works for me
It is an every day thing
every day check your chlorine level it may seem high at times but will drop even in an hour under the right conditions you will run your generator for as many hours as it takes to build it back up this you will have to learn on your own since it will be different all of the time depending on the conditions I mentioned earlier
you must also remember that during the chlorine generation you are not filtering at the capacity needed to truely filter the poolo so that is where the turning over 3 times comes in
with the intex filters they do not push enough water to create flow there by not filtering well enough to start with
Also remeber to clean that cartridge daily
if you have any more concerns you could call anytime is good
I am eastern time
586-625-2300
Posted on Aug 12, 2009
  • 297 Answers
SOURCE: I purchased an intex saltwater system, hooked it
It, did not turn your pool green. The pool was ready to turn green before you installed the intex system.
before having the system did you regularly use stabilizer? non foaming algecide? How long do you filter? There are so many variables. I will try to make it as easy as possible
We will address the salt system last right now you need to get your pool back to normal
Start by shocking it with 1-2 gallons of liquid chlorine let filter run during this time to stir it up
after 12 hours you need to brush the sides and bottom and then let settle
Now vaccum and then clean your cartridge with a strong blast from the garden hose
Start filtering again and at this point add the non foaming algaecide
the next day brush again and let settle vaccum again clean the filter again and continue this until the pool is clear
once it is clear you will want to use the algaecide once every 5-7 days.
Now a little fyi
Intex filters can not support the gl ph that is needed to keep a pool clean and crystal clear. All of there pumps are under rated for the gallon of pool that is sold with it
A pool needs to be turned over at LEAST 3 times in a 12 hour period
I will use generic #'s
If you have a 5000 gl pool and a 2500 gallon pump that is 6 hours minimum filtering time you do the math for your pool
You should also run the pump continuous. It is the only way to really filter efficiently with an intex pump
now for your generator
Although a good concept it is really a waste of money.
All the salt system does for you is to make it so you do not need to add liquid chlorine or tablets but you still need to add chemicals as mentioned above
get a test kit for salt water the ones that read #'s not color
get the salt to 3000ppm no lower than 2700 or you will not be able to produce enough sanitizer and any more than 3800 and the water tastes terrible and will usually trigger an alarm for high salt
once your pool is clear shoot for this
now to maintain it
Although you may be told otherwise this is what has worked for me for this being the 4th season with no green ever
I filter 24/7 with generating chlorine any where from 4-12 hours depending on the day.
chlorine consumption is created by many factors # of bathers heat sun rain people sneaking in with sun tan oil and so on you will need to figure out what is best for your situation
Dont forget to get a good stabilizer to help with holding the amount of chlorine in the pool usually about a pound per 5000 gl
as mentioned I also use the non foaming algaecide just follow the directions for your gl pool
I also use a water clarifyer that turns minute particles into larger particals that the filter can actually catch
and even though the filter may not look dirty clean it every day.
I use 2 one in the unit and one drying
Spray it out hard and let it dry overnight
Dont ask me why or how but a filter that is dry from the start filters better than a wet one put back in right away
Had you been doing all of this since you opened the pool the addition of the salt system would have worked fine
Good luck
Posted on Jul 08, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do i fix my saltwater pool its green?
it sounds like your chems are off, check you chlorine and PH, I go for a 3.0 to 5.0 on the chlorine side and 7.2 to 7.5 on ph,
Jul 29, 2014 | Intex 2500 GPH Filter Pump Krystal Clear...
In a 52" x 22' Ultraside Intex pool with a saltwater ionizer and a sand pump can I use pool shock to kill algae without damageing the saltwater ionizer system and the sand pump?
There seem to be different versions of algae killer - look for one that specifies that it's safe with saltwater systems (sorry, not familiar specifically with Pool Shock)
Aug 01, 2013 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System For Above Ground Saltwater Pool won't turn on
Usualy if it is some years the ball bearing on the motor shaft are rusty and if you can desasemble and use a UD40 lubricant or similar it can be fixed, or replace the bearing. One more posible case is the starting capacitor if it replaced can run the motor again.
Jun 05, 2012 | Intex Automatic Salt Water System for ...
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
I have had my intex saltwater system since June. It has done wonderful up till now. I keep getting a high salt error. I haven't added any salt. what could be wrong?
Have you had a lot of water evaporate from your pool from the heat. As the water evaporates the salt content in the pool goes up. If so then drain a fair amount of the water out of the pool and add fresh water to fill it up again. Also unscrew the connector on the right side of the electrolytic cell and make sure the plates are clean. If that doesnt fix the problem than you may have to replace the cell.
Sep 05, 2010 | Intex Automatic Salt Water System for ...
Water flow error
Water Flow should be like this
Pool Water-
May 22, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
1,480 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
