Question about Sewing Machines
How to change top blade of bernina 2000de serger
We're trying to replace the top cutting blade on my bernina serger.
3 Suggested Answers
Sewtech1
  • 69 Answers
SOURCE: 2000DE serger manual
Can help you with a bernina 2000 manual at info@absolutesewing.co.nz or try www.janomestuff.com
Posted on Jan 25, 2010
SOURCE: how do I change the top cutting blade in my Bernina 2000DE serger?
contact bernina's customer service about a manual
Posted on Feb 25, 2012
My serger won't cut
Sounds like your blades are either dull, misaligned, disengaged or broken. Examine your serger book for how to re-engage the blades. If they are engaged, make sure they are aligned correctly. If that still doesn't help check for damage.
Sep 10, 2012 | Brother 925D Serger
How do I change the top cutting blade in my Bernina 2000DE serger?
Feb 24, 2012 | Sewing Machines
How to replace the upper cutter on the baby lock? which screws to release the old blade?
I also have a babylock eclipse BLE1DX serger & here's how my book says to do it
to replace the upper cutting blade
1.open the front panel
2.remove the screw holding the upper blade
remove the upper blade
3.position the new blade in the blade slot, replace the screw.as you tighten the screw, hold the blade up in it's highest position
4.close blade cover. close front cover
hope this helps you
good luck
Sep 12, 2011 | Baby Lock Eclipse Serger
I have a Babylock 5260 serger and have changed the blades before but this time when I changed them I can't get them to align correctly. the top blade comes down and hits the bottom blade. I cant figure out...
First make sure that both blades have no burrs on the them from hitting pins. Then set the lower blade so that the cutting surface is flush with the surface of the needle plate. Then adjust the upper blade so that when it comes down to it's lowest position on the downward stroke of the cutter arm, that the cutting edge comes down past the lower blade at least 1MM. That will ensure a full cut of the blades.
Apr 26, 2011 | Sewing Machines
I own a Bernina 2000DE Serger which I purchased new many years ago. I've never had ANY trouble with it, and am quite experienced with sergers. However, when doing quite a bit of sewing on fleece the last...
Has it been serviced at all during your ownership of the serger?
The loopers can be knocked a little out of timing resulting in the skipped stiches on the heavy weight fleece occassionally. It sounds like you have tried all the usual fixes and know what you are doing.
Only other thing that might cause skipped stitches could be using a sharp needle rather than a ball point on the fleece. Otherwise maybe time for a trip to the shop??
Feb 28, 2011 | Bernina Sewing Machines
I need to thread a bernina 2000DE I would like to see a picture
try sewusa.com they have threading diagrams
Nov 27, 2010 | Bernina 1008
I want to find a manual for Bernina Serger - Model Bernette 234
go to the Bernina website
1.on the home page look on the left hand side of the page toward the top & find the support tab
2.click on the tab
3.go down the middle of the page & find the out of print manuals
4.click on the tab
5.look in the middle of the page for sergers/overlockers
6.yours should be the last model number
7.click on it-downloads easy
Nov 26, 2010 | Bernina Sewing Machines
Jan 25, 2010 | Sewing Machines
Brother 1034D serger is not cutting and is binding up
This problem is usually when the lower blade drops below the sewing plate. Look at the blade in relation to the plate and see if it has dropped below the plate, then you can reset the blade. If it is not the upper blade may be too dull to cut so it will need to be replaced.
Jul 03, 2009 | Brother 1034D Mechanical Sewing Machine
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
