Question about Honeywell Heating & Cooling
Heat on bottom floor no heat on top floor - Honeywell Heating & Cooling
    Novelist:
  • 124 Answers
Pretty vague, but i'll give it a shot. i assume that your upper and lower floors are heated by the same unit. of course if your not sure you better check to see if there is a second t stat for up stairs in case there is a second unit that heats it. there may also be a zoning system that seals off upstairs ducts unless the zone stat for that area is calling for heat. so look for a second stat upstairs if you think it may be zoned. now to you original question. lets assume the unit is not zoned and only one unit heats both. then you may have a mechanical damper in the ductwork ,usually located close to the indoor blower that shifts to force more air upstairs in summer and more air downstairs in winter, these can usually be shifted as needed to control air to upper lower and are usually marked upstairs dornstairs etc. if you have no dampers etc, then you have reason to suspect the ductwork has come apart or been crushed before it gets upstairs. you'll have to go up or under the house etc and try to find duct problems.good luck
Posted on Oct 28, 2008
Air blend door actuator
Possible bad blend door actuator .some gm cars can be relearned to the new climate control head
Jul 28, 2013 | 2001 Oldsmobile Aurora
Heat doesn't blow out of floor vents
Hi Tara,could be your blend door,could be stuck.
Jan 18, 2013 | 2007 Nissan Quest 3.5 Minivan
At times, there is water that freezes under the vegetable/fruit drawers that are at the bottom of the refrigerator. Also, at times there may be a thin layer of ice on the floor of the top freezer. I'm...
Your freezer drain is clogged or frozen up with ice blockage. Need to remove the freezer floor liner, usually 2-4 1/4" screws holding it in - slide it out. Next slowly pour hot water over ice build up and melt all ice. The drain is under the evaporator coils (small hole near center) this connects to a pan under the refrigerator that then evaporates on its own. I usually place a couple of bowls inside fresh food area on top shelf to catch excess water dripping through ceiling of fresh foods.
Next you will need to attach a heat probe from the heater under the freezer coils and feed it into the drain in order to prevent freezing up again. Use part #819043 heat probe or strip some #14 gauge copper wire and wrap around heater once and place down through drain. Recommend the heat probe 819043 to get it right the first time.
Jan 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
Water is dripping from freezer to shelves in fridge
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
Jan 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Home heating issue! hot air is cold when it reaches top floor!
Just guessing, but I'll bet your 2nd floor duct work is in the attic, and uninsulated, wrapping all attic mounted duct work with R-13 insulation and sealing it with tape will help but there is still going to be a slug of cold air pumped into the upstairs rooms each time the furnace cycles.
Dec 11, 2009 | Better Living SPP High Efficiency...
WATER LEAKING ON FLOOR BLOCKED AT BACK INSIDE OF FRIDGE ALSO ICING UP WHERE BLOCKED
The drain is most likely plugged or frozen. I suggest defrosting the entire unit and use heat gun or hair dryer on drain tube. Make sure bottom of drain tube is not plugged and that water is dripping into evaporator tray attached to top of compressor. There should be some water in here. If completely dry, then drain hose is plugged. Coathanger helps and heat.
Oct 01, 2009 | Refrigerators
Top freezer is fine but bottom refrigerator has pooling water on shelves. Some of this water freezes.
Unplug the power to the Fridge, take the items out of the freezer. There is a bottom tray that's inside the freezer that has 2 or 4 screws, remove the screws that holds the floor to the freezer and lift it out. You will probably see a sheet of ice on the bottom of the freezer. You may have to take off the back cover which is inside the freezer, it covers the evaporator. Then you will want to defrost the ice, do not use a heat gun it will melt the inside of the freezer. Best way to thaw it is leave the power off and melt it with hot water (not boiling). Either wet vac out the water as it melts or use a hand towel to mop it up. Sometimes a turkey baster will work to squeegee it out. There is a drain hole in the back that you will see as the ice begins to melt. That needs to be clear and the only way to clear it is to cover it with hot water. You will know that it clears and working when you see the water drain out thru the drain hole in the back of the inside of the freezer. By the way the drain drains thru a pipe thru a tray that's on top of your compressor. That's what heats it and makes it evaporate. Be advised that as you see that it is clearing, you can stop dumping water down there as some may get on the floor as the pan may overflow and dump water on the floor. If that happens, just mop up the water from the floor. Now put it back together again and plug it back in and you should have no further problems.
Aug 31, 2009 | Refrigerators
Just got an old ferroli wood burner but it came with no manuel
This is one of the few occasions where I recommend calling a professional. If you muck up the pressure relief valve, you could injure or kill yourself and your dogs.
Aug 25, 2009 | Plumbing
Heat always blowing on floorboard when driving even in off mode.
on the bottom of the heater case is a vaccum door right on top of the hump it has a white plastic adaptor that breaks replace with dealer part it just pops off
Apr 16, 2009 | 1996 Dodge Ram 1500 Club Cab
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Heating & Cooling Logo
145 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
