Question about VeriFone OMNI 3200 (P092-101-10) Printer
Change paper meed help to install a new roll of paper
Paper roll installation is deceptively simple.  No need to feed paper through any slots inside the machine as you might expect.  Just put shiny side of paper down, feed edge of roll out of machine and under the roller that is attached to lid, and that is all there is to it!
Posted on Dec 17, 2008
The print is faded at the bottom of the card
If the problem started when you changed label rolls, the problem is most likely the newly installed label roll. In the picture below is an extract from the Dymo Users Guide going over print quality issues.
Dec 17, 2014 | Dymo LabelWriter 400 Turbo Thermal Printer
My tec ma 1450 register won't work just blinks 0.00 and none of the keys work
With paper loaded properly, turn off/unplug register, turn MA or Service key to "Blind" position (approx. 5 o'clock), turn on/plug in register. "Status-C" will print on the receipt. Some of these TEC's won't reset after changing paper, and this procedure becomes necessary after each installation of a new roll of paper.
Jul 18, 2012 | Computers & Internet
I have a VeriFone Omni Vx510 - I keep getting a paper out message when trying to process a transaction. There is paper in the machine.
If the printer does not work properly:
• Check battery status or terminal power connection. The printer will not print if
there is an insufficient charge remaining in the battery to complete the print
operation. (For Vx610 terminals only.)
• Check if the printer is out of paper and that the roll is properly installed. Open
the paper roll cover and install a new roll of printer paper or ensure that the roll
is feeding from the bottom.
• Verify that the printer roller and paper roll dust cover are properly installed.
• If the problem persists, contact 775-358-2922 hope this help : - )
Sep 13, 2011 | VeriFone (M19755014US1) Magnetic Card...
How can I change the paper. I cannot find the correct slot to install the new paper roll
Press down on the button located on the side of the terminal to unlatch the
paper roll cover, then lift the cover up and back
Remove any partial roll of paper in the printer tray by lifting up
Loosen the glued leading edge of the paper or remove the protective strip
from the new roll of paper. Unwind the paper roll past any glue residue.
Hold the roll so the paper feeds from the bottom of the roll
Drop the paper roll into the printer tray.
Close the paper roll cover by gently pressing directly on the cover until it clicks
shut, allowing a small amount of paper past the glue residue to extend outside
the printer door.
To prevent the paper roll cover from damaging the print roller, always gently press
down on the printer dust cover to close it.
g+ypssoexzf1qaaaabjru5erkjggg==
Mar 18, 2011 | VeriFone Omni 3700
How do I change the paper tape roll on casio HR-100TM?
Pull about a foot of paper loose from the roll so it's easier to handle. Put the paper from the new roll in the back slot, and hit "FEED" this will feed it through; after you have it through, roll up any lose paper, mount roll in holder, done, Should take about 3 minutes
Mar 02, 2011 | Casio HR-100TMPlus Calculator
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
I ran out of paper and purchased a new roll of paper. I do not know how to install the new roll of paper.
Just drop in, the paper needs to come toward you from the bottom and just past the paper cover once closed. If you have a paper roll spindle, insert and line up with the spindle guides on the machine.
Mar 20, 2009 | VeriFone Omni 3200 Printer
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
VeriFone OMNI 3200 (P092-101-10) Printer Logo
153 people viewed this question
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
