Question about Baxter OV300E Stainless Steel Electric Oven
How do I fix the flame sensor in a baxter oven?
  • 43 Answers
Take off the right side panel and open the control panel door. Take a long screw driver and stick it in the hole where the flame sensor wire goes and remove the screw holding the flame sensor in place. Clean the metal rod on the flame sensor with a piece of fine grit sandpaper or emory cloth. Put flame sensor back in, make sure no insulation is touching the exposed metal part of the wire connector.
Posted on Jul 15, 2012
Baxter ov500 keeps shutting off when turning on and eventually it will stay on
presume its an electronic gas oven.
on the main burner in the bottom of the oven (you might need a screw driver to remove the lower cover inside the oven) you will see a spark plug that makes the spark for ignition and you will see what looks like a bent bit of wire that is in the flame when its on. the bit of wire is the flame sensor. check that it is in the flame and hasn't moved. also give it a clean with a bit of fine steel wool to remove any carbon that might have built up on the flame sensor.
also here is a link to a free manual down load.
http://www.bakeryequipment.net/Baxter_OV500_Series_Rack_Oven_Manual_p/ov500ge.htm
Sep 22, 2016 | Baxter Ovens
Rotating Rack. How do I replace flame sensor?
How To change a flame sensor on a furnace and what to ...
? 17:13
www.youtube.com/watch?v=iDnkdKsZhc0
Dec 8, 2011 - Uploaded by kevin miller How To change a flame sensor on a furnace and what to look for. ... The gas flame heats the electrode, allowing electrons to be emitted as from the ... I found a Honeywell "universal"replacement unit for my furnace on eBay for ...
Aug 19, 2015 | Baxter Ovens
Pilot light either won't light or won't stay on
Check for a draft first that is randomly blowing this thing out and second check the gas regulator.
Mar 12, 2014 | Baxter Ovens
Can get the oven to stay lite
If the oven lights for 4 seconds and shuts off you are experiencing an ignition module safety lockout. First verify that the flame is lighting at the top of the burner and reaching the very bottom venturii tube where the flame sensor is located. If this bottom tube isn't lighting or it takes longer than 4 seconds to light then you have a dirty burner and it needs to be taken out and rinsed. If the bottom tube is lighting and then going out your flame sensor needs to be cleaned, which is easy.
Mar 21, 2012 | Baxter BXA2G Stainless Steel Gas Single...
Flame does not always stay on after ignition, sometimes it does and when it doesnt you open and close the door for re- light ?
Opening and closing the door will reset the ignition sequence, do not do this repeatedly as you could cause a build-up of unburned gas in your heat exchanger and damage it. Instead verify that your ignitor is glowing, then see if the burner lights and make sure the flame carries all the way down to the bottom of the burner. If the flame stalls halfway or doesn't make it all the way to the bottom in 4 seconds after 3 attempts you will experience an ignition lockout, a safety feature built into your ignition module. If this is the case your burner needs to be cleaned and serviced, have a professional do it.
If the flame is reaching the bottom of the burner but still going out after about 4 seconds then you have a dirty/broken flame sensor. You can attempt to clean your flame sensor by removing the screw that holds it into the burner. With it removed it will look like a metal rod going through some ceramic, clean the metal rod part with a wire brush or emory cloth (fine sandpaper). Replace the flame rod and try again and see if the burner stays on this time. If it still goes out your burner needs to be serviced by a licensed technician.
Feb 11, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Water coming out oven no steam and it will not get to tempeture
If your oven isn't reaching temperature you will not get steam. Turn the oven on and verify that the oven is calling for heat by looking in the temperature window next to the arrow that says "heat" or "on," if the set temperature is 5 degrees higher than the actual temperature there should be a small red dot next to the arrow. Then observe the burner, does the exhaust fan come on, can you see the ignitor glowing, does the burner light, does it stay lit or go out after 4 seconds? You could have a dirty flame sensor, the small rod with a wire attached to it at the top of the burner, remove the flame sensor and clean it with a cloth, wire brush, or emory cloth.
Jan 02, 2011 | Baxter OV300E Stainless Steel Electric...
Burners will not stay on until set temperature is reached they shut off and on eratically....please help...
Have you tried cleaning your flame sensor? The little metal rod at the bottom of the burner can be removed and the metal rod that sits in the flame should be cleaned with a wire brush or emory cloth (fine sandpaper).
Sep 30, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Baxter OV300E Stainless Steel Electric Oven Logo
156 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
joneable
Level 1 Expert
Jerry Kramer
Jerry Kramer
Are you a Baxter Oven Expert? Answer questions, earn points and help others
