Question about Kenmore 62602 Electric Dryer
Kenmore dryer 90 series
Why did we get cut off?
  • andydale Feb 27, 2010
    how to hook the cord for this dryer?
    Scholar:
  • 64 Answers
I’m so sorry my pc crashed on me..... Power Supply went out and I just got a new one put in.....I hope you got your answers......If not please let me know so I can help
cbinny1
Posted on Oct 29, 2008
  • Craig Binford
    Craig Binford Oct 30, 2008
    Did you still need help with this issue?
    cbinny1
  • 90 Answers
SOURCE: Kenmore 90 Series
bad motor
Posted on Feb 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore 90 series dryer's pilot light is out.
If your flame sensor is open then the ignitor will not fire up. Read more
Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
Posted on Mar 07, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 90
The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All Kenmore dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Aug 21, 2009
  • 2667 Answers
SOURCE: 9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Posted on Nov 07, 2009
jsrock516
  • 5911 Answers
SOURCE: My kenmore series 90 dryer has no heat but it runs
The life of the dryer can be indefinite if maintained properly. I've worked on Kenmore dryers that were over 20 years old. Components do wear out from normal wear and tear sometimes and require replacement. Most of these components are not expensive and can be replaced by the average do-it-yourselfer. However, not maintaining the dryer exhaust ventilation can shorten the life expectancy of the heating circuits. Most commonly, this problem is caused by a blown thermal cut-out, or failed heating element.
If the dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If you have any questions, please post back with your complete model number (usually located on a nameplate around the door opening) so that I may be able to provide you with better assistance. I hope you find this helpful.
Posted on Dec 16, 2009
Not getting true cuts on sliding miter saw.
Sounds like the blade isn't parallel with the sliding mechanism.
Oct 24, 2014 | Saws
Tip
Temp cut off/cut in
Any thermostat, it's calibrating to cut off at the end of 2nd beginning and cut in 2nd ending of temp.<br /> Ex: In heat mode, If you set @ 68 degree, it will cut off 70 degree beginning and cut in at the end of 66 degree. <br />In cool mode, if you set at 68 C degree it will cut off at the end of 66 and cut in will be at the beginning of 70 degree.<br /><br />
on Jan 10, 2011 | Heating & Cooling
What can i do with kitchen shears?
Kitchen shears are a very useful item to have in a kitchen. They can easily and comfortably substitute a knife in many tasks. For example:
- Cutting fresh herbs and spices
- Cutting the roots off vegetables before using them
- Cutting all kinds of raw pastries (like phyllo) and doughs (pizza, pasta etc)
- Snipping pieces of cheese
- Cutting poultry, meet and fish both raw and cooked (for example cutting off wings, cutting poultry into smaller pieces, cutting scales and finns off fish, cutting rotisserie chicken, cutting open crab legs, trimming fat off meat etc)
- Cutting fruits and dried fruit
Shears are also very useful in a kitchen as normal scissors, to cut string, wrapping paper etc
Oct 17, 2013 | Home
What is the proper way to cut drywall with a razor knife?
use a level or straight piece of drywall, and place it along the drywall you want to cut, cut with the knife along the straight edge (you dont need to cut through the entire width of the drywall). Then fold the drywall on the cut, and while folded cut the other side of the drywall paper. you should have a clean, straight cut
Jan 16, 2013 | Drywall
HOW DOES THE KNIFE GETS ALIGN SO IT WILL CUT?
You have to tell it to cut. Your software has to know there is a knife attached to the printer, so it will know to cut. You have to program it to cut, -where and how you want it to cut your supplies.
Press the feed/cut button and hold for five seconds. It should feed and then cut your supplies - this will tell you whether the knife is working and if it's cutting straight.
Jan 13, 2011 | Paxar Monarch 9850 Thermal Printer
How do i adjust air pressure cut out
Square d recommends that the pressure switch be adjusted to specifications of the particular switch (which is sold in pressure ranges preset at the factory). The switch will be erratic it adjusted out of the factory setting range.
From Square D: (adjust the desired cut-in pressure first, then cut-out)
Cut-in: The large spring controls the cut-in pressure. To make adjustments, turn the nut clockwise (compressing the spring) to raise the cut-in point or counterclockwise to lower the point of cut-in.
Cut-out: The small spring is the differential adjustment and controls the cut-out pressure. To raise the cut-out pressure turn the small nut clockwise (more differential); to lower the cut-out pressure turn counterclockwise.
Sep 24, 2010 | Square D 9013FHG14J52M1X Air Compressor...
Tile Saw Troubleshooting
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Kenmore 62602 Electric Dryer Logo
1,182 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
