Question about Pioneer VSX-405 Receiver
How to connect my subwoofer to my vsx-405 receiver
Subwoofer conected to receiver/ speakers connect to subwoofer
    Top Expert:
  • Pioneer Master
  • 74,383 Answers
Hello
Try to download the user manual to Pioneer VSX & THX user manual. click here to down load the same. You will get details of it connections from the manual.
http://www.dataentryjobs.us/67948.html
Posted on Feb 25, 2012
SOURCE: Pioneer VSX-D606S subwoofer set up
If you push the middle of the remote the select I belive it it it will give you options on the receiver. There is one which says subwoofer on / off. Hope that helps.
Posted on Jun 02, 2007
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Posted on Jun 24, 2008
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
gherna1
  • 190 Answers
SOURCE: My pioneer audio/video stereo receiver vsx-405 is
Here it is:
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=Pioneer+VSX-405&uuid=12569174522640
Posted on Oct 30, 2009
SOURCE: pioneer vsx-305 need wiring diagram for this
I have problem with connecting subwoofer to receiver.
Posted on Jan 28, 2010
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
Is it possible to hook up a powered subwoofer to this unit? It has a centre pre-out, but nothing labelled for a sub, and the manual is useless. This is a very nice old receiver, works perfectly, and I'm...
The only way to hook a powered subwoofer up to a VSXD903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
(To the guy [dunnbiker] that says there's no rear channels: You're wrong.) The VSX-D903S has 2 stereo (A/B) channels, dual center channel (place center speakers to the left and right, or above and below the screen), and two rear satellite channels. It is a 3-Ch Logic/Dolby Pro-Logic Surround equipped receiver, not a DolbyDigital/DTS multichannel x.1 surround unit.
Dec 19, 2010 | Pioneer VSX-D903S Receiver
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
No Sound from Subwoofer
The original Pioneer subwoofer has its own amplifier built in to the speaker, so the only cable required on the original speaker is a single RCA cable. To connect a different brand subwoofer to the Pioneer you will have to make sure that you have a subwoofer with the same specs. It will need its own built in amp to work, as you can only connect it with one RCA
Jul 31, 2009 | Pioneer VSX-818V-K Receiver
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
587 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
