Question about Dell 5100cn Laser Printer
RESEAT FUSER WE JUST GOT A NEW FUSER FOR OUR 5100CN PRINTER AND WE HAVE REPLACED IT, BUT IT KEEPS TELLING US TO RESEAT FUSER
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Hi G,
99% of the time the error is the fuser. Either it is damaged, or just not locked in place, and with power off, reseating it will fix the error. Since you just replaced the fuser, I guess the question is did you do it because it was also giving this error, or because it reached EOL ( end of life ).
If it was for EOL message, I would try reinstalling it. If the "reseat fuser" error goes away, but comes back with the new fuser again, then the new fuser you purchased is defective and should be returned or exchanged.
See the information below to correctly troubleshoot your issue.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Posted on Oct 30, 2008
We have a Phaser 7300N that will intermittently run jobs without fusing. as you can imagine this makes one heck of a mess. we had this problem once before so we replaced the fuser, that only worked for a...
These are 2 different problems. The fusing issue is that the fuser roller is controlled by the "ATC Anvil calibration". This requires Transparencies (PN 42527801) to be run through the Manual feeder. You may need a technician for that, or buy a manual
The "reseat message" is probably a warping "top cover inner frame" 116-1548-00. You might need to replace that whole top.
Whit
Item, Inc.
May 24, 2010 | Xerox Phaser 7300DN Laser Printer
5100cn has sections of printing that smears
You have uneven heat from the fuser. May need new rollers and bearings, or maybe a paper scrap wrapped around the rollers.
Aug 11, 2009 | Dell 5100cn Laser Printer
Xerox fuser for Phaser 6300 installed in Dell 5100CN- Fuser ID er
I would only use the part designated by the manufacturer.
Feb 24, 2009 | Dell 5100cn Laser Printer
ERROR CODE 010-387 RESEAT FUSER
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
Hope this helps!
Jan 08, 2009 | Dell 5110cn Laser Printer
Low voltage power supply
What is the error message you are getting with the new fuser. Is this the same error you were getting before changing the fuser? If you changed the fuser because the old one was just at EOL ( end of life) but did not give you an error, have you tried to reinstall the old fuser.
It is possible that the new fuser was damaged in shipping, or not properly seated.
If both the new and old fuser give the same error message, then yes, I would agree that the LVPS would be the next part to replace, however, if they have different errors, then you probably have 2 bad fusers ( or one that is EOL, and one that was received damaged).
Before changing the LVPS, make sure you follow the steps below prior to the LVPS steps.
as far as where to purchase it if you do in fact need one, you can always do a google and ebay search for "Dell 5100cn LVPS".
I can provide you with replacement instructions if it comes to that.
See below for the actual troubleshooting needed for the fuser.
Oct 23, 2008 | Dell 5100cn Laser Printer
010 397 Error Message on Dell 5100cn
Apr 04, 2008 | Dell 5100cn Laser Printer
Fuser change help
is it asking you to reseat the fuser or reset the fuser?
These printers do not have any kind of reset for new consumables such as the fuser. They will be automatically detected by the printer. Though sometimes it will take several hundred pages before the proper levels are detected on the new parts.
If it is asking you to reseat the fuser then you need to open the front panel and remove the fuser. Once it is out make sure that there aren't any pieces of paper or protective plastic that are covering any of the connectors.
Once that is done, simply slide the fuser back into place and re tighten the screw that holds it in. After the fuser has been reinstalled you will need to turn the big blue knob on the fuser several turns in the direction of the arrows that are printed on the knob.
You can do this procedure either with the printer turned on or off.
Feb 15, 2008 | Tektronix Phaser 740P Laser Printer
Horizontal Striping Problem on a Dell 5100cn
As you have just replaced the drum you may have a faulty drum unit put old one back in a test if lines go way then return drum to store and get a replacement. If they do not go the check the toners and the fuser unit.
Thanks J
Jan 21, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Logo
935 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
