Question about Whirlpool Refrigerators
MY DRAIN TUBE IS CLOGGED AND WATER IS RUNNING INTO THE REFIGERATOR ON THE SHELVES AND ONTO THE FLOOR
Roper 21LMXKQ Water in the refrigerator on shelves and running on floor. I figure the drain tube is clogged but don't know how to unclog it.
    Problem Solver:
  • 13 Answers
Get one of those unclogging sticks
Posted on Feb 24, 2012
aborcass
  • 2651 Answers
SOURCE: water leaking in refrigerator on shelves, drawers, and under draw
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Feb 09, 2009
aasc
  • 1606 Answers
SOURCE: water leaks from freezer onto top shelves.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or Copper solid wire , ( a ground wire or fence post tie ) 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on May 05, 2010
SOURCE: Water in Freezer bottom
drain line is blocked check bottom tray if is collecting water if not drain line blocked
Posted on May 13, 2007
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
  • 1314 Answers
SOURCE: refrigerator
there is a peice sticking out the back wall of the refridgerater compartment just under the top back wall that goes to the defrost drain see if its clear its a square peice also check the drain hose at the back of the unit at the bottom to see if the hose is clear some times they get clogged with alge and wont drain
Posted on Mar 10, 2008
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have the subzero 632 side by side and there is water dripping from under the bottom drawers onto the bottom of frig and then onto floor. Could that be the rubber gasket stripping on the bottom of the...
Behind the crispers and the shelves at the bottom is a drain trough. This drain trough is clogged and would need to be cleared by air pressure. You can use canned air you can seal the opening to keep the pressure in the tube. Once cleared you should be fine.
This happens when food or foreign object get into this trough clog or slow water flow out of the fridge section.
I hope this helps.
Oct 05, 2013 | Sub-Zero Overlay Design 632/O Side-By-Side...
There is a hole in the bottom rear of the freezer of my side by side full of water and the over flow is frozen all across the bottom and it leaks onto the floor
How To Clear the Drain Tube Before clearing the drain tube, unplug the refrigerator or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2011 | Refrigerators
WATER IS COLLECTING ON SHELVES-LOST MANUAL-DOES IT HAVE A DRIP PAN UNDERNEATH
Your defrost is working - but the drain tube is clogged. It may be debris causing the clog - but more than likely it is ice.
Access the drain tube and defroster behind the back wall of the freezer. Remove built up ice on the floor of the freezer and the drip tray under the freezer coil and defroster coil. Don't use any sharp tools! Locate the drain tube at the low point of the drip tray. Attempt to clear it of ice by using a turkey baster (or the like) filled with hot water. Direct a stream of hot water from it into the drain tube. Ice may be an inch or two thick in the tube. Once the ice is clear, water should flow easily and quickly down the tube to the drip pan under the fridge - where it will be evaporated away.
To prevent the ice from forming in the drain tube in the future, hang some metal wires (preferably copper) from the the defrost coil down into the drain tube. Make the sure the wire is long enough so that it extends at least as far into the drain tube as the ice had clogged. The metal wire conducts the heat from the defroster down into the drain tube - thus preventing ice from forming - and clogging the drain. Use copper or aluminum wire if you can - steel coat hanger wire can be used if you can't find any copper or aluminum, but it will rust. Copper electrical wire # 14, # 12 or even # 10 is ideal, but the thicker the wire is the harder it is to work - it may be easier to use 3, 4 or more pieces of the smaller # 14 gauge wire instead of 1 or two pieces of # 10.
This worked for me and will probably work for you, too. If this was helpful, please rate my answer "4 thumbs up" - thanks!
Jun 09, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Clogged defrost drain tube.
It should be just below the evaporator coils. The panel covering the fan should also be the one covering the drain tube. You'll probably have to pull the shelves out to get the panel off (depending on the model, sometimes you'll have to pull the back panel off too, sometimes it's just on the top.)
Mar 30, 2010 | Admiral 26 cu. ft. Side-By-Side...
Water is accumulating in the bottom freezer and freezing...I continually have to chisel it out. We have tried defrosting it but have the same problem a few days later.
Hi.This will normally be caused by a clogged drainage hose or plug. There is a drain leading out of the freezer and another from the refrigerator. In top freezer models, the freezer may drain the water onto the back wall. It actually runs down the wall to the refrigerator floor drain. In other cases, there may be a drain tube leading out the freezer. The refrigerator drain is either located on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel. In side-by-side models, the freezer and refrigerator will probably each have an outlet to the drain pan under the appliance.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Dec 09, 2009 | Kenmore Refrigerators
Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Sep 13, 2009 | Kenmore 71112 / 71114
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Dec 22, 2006 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
281 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
