Question about Maytag Neptune MDE5500AY Electric Dryer
How to change the fuse in a maytag neptune dryer
My dryer is just cold air when in cycle I was told by maytag that the fuse probably needs to be changed how do i do this?
  • 41 Answers
It could be a thermal fuse, or it could be your element. the only way to know for sure ( without just replacing parts ) is to test them with an ohm meter on tone.
to get to these parts, you need to open the door and remove the 4 screws ( 2 on either side ). then you can remove the front panel. you now have access to the element and the thermal fuse which is on the element canister.
if you get tone, then the part is good. Joe
Posted on Nov 18, 2008
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
Aug 04, 2012 | Maytag Dryers
Maytag neptune washer can not change the wash cycles
1) test the timer probably faulty,tight connection wires see the diagram how to test,and see the diagram in line black, how the contacts from timer control everthing in the washer.
2) problem of cold water, is the cold water turn on? consult your owner manual for to see if acting abnormally
3) check the selector is o.k
God bless you
Jul 18, 2012 | Maytag Neptune MAH6500A Front Load Washer
Cold blooded neptune
check the hi-limit switch on the element case and the cycling switch also there for continuity,then check the thermal fuse for continuity its in the exhaust vent area
Mar 03, 2010 | Fisher and Paykel DEGX1 Electric Dryer
It won't do anything. The display says 8.8.
Blown duct fuse.
Probable cause:
lint, loose blower wheel, air restriction
NEPTUNE REPAIR MANUAL
Dec 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
No hot air for dryer
this is most likeky thermostat you can find here http://www.partstap.com/
Feb 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 14, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
1,005 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
