Question about Jenn-Air JCD2389G Side by Side Refrigerator
Warm refrigerator Freezer works refriderator is warm on top cooler on bottom. What and how shoud I repaird
    Novelist:
  • 161 Answers
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can before anything starts to thaw. Put everything back in, turn it on and this should last a couple of days.
Posted on Dec 17, 2008
Freezer is working, refrigerator is warm
You probably have a defrost issue with the freezer. Cold air is passed to the refrigerator section from the freezer, when the freezer does not defrost air flow to the refrigerator is eliminated causing the refrigerator to warm up. Check for icing on the back wall of the freezer. If no ice on back of freezer, check the damper assembly going to the refrigerator section.
May 26, 2015 | Refrigerators
GE Profile refriderator PSC25MSWA is frosting/icing on bottom of Refriderator side
Try defrosting entire unit. Put all food, freezer and refrigerator sides in coolers with ice. Unplug unit and wait at least 24 hours for unit to completely defrost, if neccessary open doors, plug unit back in and see how unit functions. By doing this lines that carry freon should become unclogged.
May 05, 2014 | GE GSS22SGM Side by Side Refrigerator
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Kenmore Freezer works, but refridgerator is warm
Either there is a refrigerant leakage or if it is a no frost refrigerator air ducts to the refrigerator is closed due to frosting. Switch off the refrigerator for 3 hours and restart again.
Aug 15, 2009 | Refrigerators
Top of the freezer not freezing
SealedSystem problem. You need a "Certified Technician".
Apr 26, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Refridgerator leaking water
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Jun 26, 2008 | Magic Chef CTF2125 Top Freezer...
Jenn Air JCD2389GTW Refrigerator problem
Check the back wall of the freezer section for frost. If it is frosted you do have a defrost problem. Timer or heater related. More economical to repair than to buy a new system.
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Build-up of a mountain of ice in freezer
replace the heater tube inside the freezer under the cooling fan good luck
Sep 22, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
176 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
