Question about HP DeskJet 712c InkJet Printer
Why isn't my deskjet 712C printing color?
We haven't used our printer for about 4 years; I had to buy an adapter so it would plug into the computer, but it had a driver that installed with it and it prints black perfectly but no color. Both black and color cartridges are new and I tried cleaning the metal contacts like it suggested in an online self-help. Did I get a defective cartridge?
Soulvisitor
  • 1113 Answers
SOURCE: HP PSC 1610 All-in-one with message to check the Color print cartridge
Theres a pretty sure bet when the fuel light comes on in your car, fuel will fix it,
its a bit like that these cartridges fixs most things expesally if you have never changed it in a year and a half,
Exp date is shelf life,
End life of cart. is out of ink or error,
Machine uses colour ink when cleaning regardless if you use it or not that just uses more
With all that being said I've also had these with cartridge housing problems causing the fault vay rarely
And then if you look at prices of new inkjets with a years warranty and new inks against the just the price of both your inks then I think you may Buy another.!
If you get 3 years out of a inkjet your doin extremly well, machines dont last and arnt meant too!
If you rarely do colour I would tell you to look at a B/W Laser printer instead, inkjets are expensive to run, cheap to buy fail a lot
Laser machines run so so so much cheaper like 2cent compared to 20c a sheet, they are reliable, if you really need a colour print go to print shop and receive reletavely cheap quality colour prints or use a friends and let them have the problem of supporting an inkjet.
Laser toner based machines are now as cheap as inkjets but better except they dont do colour.
Posted on Oct 19, 2007
yooperbud
  • 8637 Answers
SOURCE: I have a HP Deskjet F380 All-in-One. Error light keeps flashing.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
solasknows
  • 199 Answers
SOURCE: HP Deskjet 712c Printer will not print in black & white
you need to check the head of the printer, im sure is bad, it depends how old is the printer but the head on the printer goes bad if printer has not been used for long time or if you left the old empty cartridge seating inside for a lont time, you can do a head check on the settings of the printer and also do an alignment thank you
Posted on Jun 16, 2009
SOURCE: HP Deskjet 4280 does not print. 'E' error on Control panel button
I had the same problem. It was solved once I bought an original color cartridge. Refilled cartridge seems not to work on this printer. Glad if it might help.
Posted on Jun 18, 2009
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
Printer won't print color
when you go to print something, the screen comes up with the print instructions
no of copies
print all print pages etc
there you will find a properties tab
click on that and it takes you to paper size next tab is black & white or color click on color and then down the bottom click on default
as to problems with hp printers , I use a hp deskjet 2050 series now over 9 years old and still capable of printing out manuals up to 1000 pages long so makes me wonder if you are expecting too much from your printers and why with so much dissatisfaction with a product, you still persist in buying the brand
Apr 30, 2017 | HP Deskjet 3520 e-All-in-One CX056AB1H
My DeskJet 712C will not print anything when I try printing in color, it will, however, print with just black when I set it to do so. How do I get it to print in color, too?
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Sep 07, 2012 | HP DeskJet 712c InkJet Printer
My HP DeskJet 712c InkJet Printer's "ink light" won't stop blinking!! I have tried changing ink cardridges, checking for paper jams, unplugging and replugging cords and re-starting computer. None...
Hello.
Give this a try:
1. Power off your printer
2. Remove and reinsert the cartridges. You should hear a "click" when properly seated.
3. Power on printer.
4. If light is out, print a test page for realignment.
Note: Be certain that the tab is removed from the cartridges and you are using "genuine" HP cartridges.
Hope this helps.
Oct 31, 2010 | HP DeskJet 712c InkJet Printer
My hp 712c printer prints only the pink band when I run a color test. I have replaced the original cartridge. Any ideas about the cause and solution.
The cause is either:
* clogged ink-jets not allowing yellow & blue ink to move from the ink-cartridge onto the paper;
* busted electronics inside the printer, causing the ink-jets to not "spray" at all.
Use the software to try a "print-head-cleaning" cycle.
If that fails to improve things, it's time to replace the printer.
Jun 24, 2010 | HP DeskJet 712c InkJet Printer
PRINTER (not web camera!) HP Deskjet 712c Printer began printing mostly blackPrinter began printing mostly black & magenta so I replaced the color cartridge. Color did not improve and then black...
First run the CLEAN HEADS and see if that helps. If you don't use your printer at least once a week the Print Heads get dried out and will not allow the ink to pass through to the paper.
Go to control Panel and click on Printess. Then when the window comes up, CLICK on Properties TAB and then in the next window, CLICK on CLEANING.
You may have to replace your PRINT HEAD if that doesn't work.
Hope this is of some help. Bud
Feb 06, 2010 | Computers & Internet
Jun 16, 2009 | HP 5069-4515 Keyboard
Can't get rid of blinking cartridge light on hp deskjet 712c
maybe they need replaced..if already done..then run a calibration and clean cycle from print manager panel
Oct 13, 2008 | HP DeskJet 712c InkJet Printer
Deskjet 712c
yes..that means there is something amiss with your print drivers or print manager.
www.hp.com is a good place to get new versions of each.
May 09, 2008 | HP DeskJet 712c InkJet Printer
HP Deskjet 712c prints only blank
I had the same problem and what worked for me was to make a PDF and then check the box "print color as black" I only say this is a fix because I was desperate. I realize this is a time consuming workaround. also if you are going to do this make sure that your printer settings are for Color but then the print color as black box is checked. hope that helps.....
Jan 25, 2008 | HP DeskJet 712c InkJet Printer
HP DeskJet 712c InkJet Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
