Question about Canon imagePROGRAF iPF8000 Printer
How do you start aCanon iPF710 plotter in service mode?
I am getting an error message Harware error 03800500-2F2F I have version 01.40
4 Suggested Answers
  • 1116 Answers
SOURCE: Tried upgrading Canon iPF710 firmware
Power off and unplug the printer for several minutes. On power on the printer had the same "ERROR E196-4040 Call For Service" after Initialization. Next start the printer in Service Mode, turn on the printer while holding down the [Paper Source/Feeder Selection] button and [Information] button until Initializing appeared in the display. An "S" will appear in the upper right of the version display. Power down and do a normal Power On and the printer should do a normal initialization and came On Line.
Posted on May 28, 2011
Testimonial: "This was spot ON!!!"
  • 79 Answers
SOURCE: Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Posted on Mar 17, 2009
SOURCE: My Canon iPF 9000 continues to have Hardware Errors 03800500-2F2F
Clean the area below where the carriage rests, where it dumps ink into the maintenance cartridge. Apparently the sensor is not detecting how much in is being dumped or not even detecting ink at all.
Hope this helps
Posted on May 04, 2010
Hardware error
hello, can you specify what error number is?...i have a service manual for this ipf710 plotter and i can tell u what is wrong with it or you can download the service manual from the below link:
http://goo.gl/daFE3c
good luck
Sep 11, 2013 | Canon imagePROGRAF IPF710 Printer
Error carriage
hello this error means that "A/D converter outside trigger output stop" you will need the service manual to help you it will save u $ when u have problems, you can download it from the below link:
http://goo.gl/lrcIW7
good luck
Sep 10, 2013 | Canon imagePROGRAF iPF710 InkJet Plotter...
Error code E161-403F
I have had two of my Canon plotters give this error.message, I had to manually move the carriage unit and replace the printhead. On one of the plotters the error message returned, on the second plotter I was able to go into service mode where it asked me to replace the printhead. I just went though the motions since the printhead was brand new and I was able to get the plotter to function correctly.
Mar 05, 2013 | Office Equipment & Supplies
Tried upgrading Canon iPF710 firmware from 1.35 to 1.40 on 2 separate plotters and received a !Error E196-4040 Call for service message. Plotter will not come to a Online status.
May 28, 2011 | Canon imagePROGRAF IPF710 Printer
Canon IPF700 error message E161-403E, how do I fixt this?
Welcome to FixYa
Error message E161-403E is a print head over heat indication.
Turn off and turn on the printer see what will happen. If error still exist then you have to replace the print head.
Before you have to update the firmware to the latest version.
Try to access the service mode in order to update the firmware
Error will be removed.
If you have already tried above and still you have error then it is probably that your Canon printer is in need of servicing by a service professional.
So go to the Canon Service Center. If you want to get support on Call then Call Canon Support by phone, at 1-800-OK-CANON (1-800-652-2666)
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 11, 2011 | Canon imagePROGRAF IPF710 Printer
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
Error-03130031-2F26
I have downloaded the drives for the canon ipf710 but cant seem to get the online connection working
Oct 29, 2010 | Canon IPF710 A0 Wide Format Plotter...
I get a message that the ink system has failed and error message 0xc18a0001. I have turned it on and off again, also tried the suggestion on the HP web site - didn't work.
Please remove off your printer and uninstall the printer. Later reinstall the printer software and then connect the printer. Your harware- printer- will now be detected and installed into the PC. Now check and make a test print, the printer must work right now . If it is still showing an error of the Ink , use the maintenance key for ink chane before you remove the cartridge. Change and check . Good day
Aug 16, 2010 | HP Photosmart C7180 All-In-One InkJet...
Canon imagePROGRAF  iPF8000 Printer Logo
426 people viewed this question
old marine
old marine
